10-08-2020, 04:48 PM | #15 |
After modifying the manifold this appears to be straight forward. I’ll port mine myself too when I get one.
Thanks for pictures and the post. Now to accumulate the parts.
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“ Last edited by Trochoidal; 10-08-2020 at 05:26 PM. |
10-08-2020, 05:56 PM | #16 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
What is the purpose of the big long thin piece thats bolted up behind the throttle body adapter?
Also I'm assuming buying the Katech LT1 to LT5 throttle body adapter and buying an OEM LT5 TB is still the cheapest way to get a higher flowing throttle body? And I thought the Katech adapter was tapered to fit a stock non-ported LT1 manifold size? Last edited by cmitchell17; 10-08-2020 at 06:07 PM. |
10-08-2020, 07:10 PM | #17 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 10-08-2020 at 07:47 PM. |
10-09-2020, 09:32 AM | #18 | |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
10-09-2020, 10:06 AM | #19 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
https://www.camaro6.com/forums/showp...&postcount=128 |
10-09-2020, 10:10 AM | #20 |
Drives: like an old lady Join Date: Jun 2012
is there any reason not to use any of the other adapters vs katech? i'm using the ict billet adapter and it seems fine.
the only issue i have is the adapter pushed the rotofab elbow into the fan cage. it all fits but i'm not real happy with it.
10-09-2020, 10:40 AM | #21 | |
I used 2 nuts and I would recommend 2 black spacers. You need to use both long bolts that come with strut tower brace. So you need to find 2 more longer bolts.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
10-09-2020, 10:46 AM | #22 |
No reason for the Katech other then they had a good price and they are close to me. I am using a custom made intake elbow that I purchased and cut/grind to clear that area.
10-09-2020, 01:21 PM | #23 | |
I can't figure out from standard engine theory, if there is a standard accepted WOT vacuum that is normal? Or if it depends on the MAP location? Or if the stock systems account for the velocity of the airmass when sensing the pressure at the MAP port? I have found on my logs that once I got WOT I get higher barometric pressure readings, which I assume is just a normal part of the GEN V system? I think it may have something to do with the new multi wire maf sensors that I believe have the humidity and barometric sensors incorporated into them, which would make sense that going WOT with full airflow velocity would disturb their readings. Probably a better question to post to the HP Tuners forums than distract from your thread. |
10-09-2020, 04:48 PM | #24 |
Possibly might need a tune. She is running leaning, will give it a few days to see if ECU corrects itself. I want a tune anyways to squeeze a few more HP out of the car.
10-10-2020, 01:12 PM | #25 |
2018 SS A8 11.85@117.06
Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
no spacers, got about 1/4 inch clearence
DARK KNIGHT
2018 SS A8 11.85 @ 117.07 GPI Tuned E85 stock tires Roto Fab CAI LT 2 intake |
10-10-2020, 01:20 PM | #26 |
But you have a bald kitty. Lol
10-10-2020, 02:16 PM | #27 |
I'm just glad it fit, ran awesome right from the start, stock Soler throttle body, sounds meaner too.
DARK KNIGHT
10-10-2020, 02:40 PM | #28 | |
Did u get any check engine light. I did. Maybe I should try a battery disconnect.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 10-10-2020 at 06:00 PM. |
