09-04-2019, 10:58 AM | #1 |
Drives: 2009 Corvette Z06 Join Date: Aug 2009
Presenting the 2016-2019 GEN6 Camaro ACS Lower Rocker Brake Intake Scoops Painted
These ACS Composite Lower Rocker Camaro Brake Intake Scoops from Southern Car Parts are bolt on panels adding a rear lower brake intake scoop to your 2016-19+ 6th Gen Camaro. Whether it's for an aggressive look or improved brake cooling capability, lower rocker scoops will add a distinctive look to the side profile of your car. Manufactured in RTM composite this kit is a bolt on mod anyone can install. Simply set the supplied template in place, drill 3 holes and bolt on the panels. Detailed and accurate trim bezels are included, functional brake cooling ductwork can be added (not included), extra trimming is required for ductwork. Note: These scoops are not compatible with ACS rockers. Painted any Camaro color is optional, By default the trim bezel will be painted Mosaic Black if no color chosen. Conversion Kit Includes: *Passenger Side Scoop Panel *Driver Side Scoop Panel *Passenger Side drilling / trimming template *Driver Side drilling / trimming template *Passenger Side Trim Bezel *Driver Side Trim Bezel *Mounting Hardware *Instructions APPLICATION: 2016, 2017, 2018, 2016-2019 GEN6 Camaro ACS COMPOSITE Lower Rocker Brake Intake Scoops Painted Sales thread available here: https://www.camaro6.com/forums/showt...0#post10612710 |
09-09-2019, 05:49 AM | #2 |
What do you guys think?
09-09-2019, 10:22 PM | #3 |
Drives: 2017 Super Sport Cam. Join Date: Feb 2018
09-30-2019, 08:12 PM | #4 |
SHRFT
Drives: 2017 2SS vert 50 anniversary Join Date: Dec 2018
I like the look when finished and this product can be functional.
Even though all the mosquitoes are roasting in HELL, I still don't like winter.
10-10-2019, 09:24 AM | #5 |
10-10-2019, 09:32 AM | #6 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Looks the part. Agreed, would only ever consider if proven functional.
10-10-2019, 09:43 AM | #7 |
No not a fan of them! To me they look out of place on the 6gen but someone else might like them.
12-31-2019, 09:01 AM | #8 |
12-31-2019, 09:18 AM | #9 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
The picture here on Camaro6 and your web site are not that clear. Better pictures please to give it an honest opinion. First thought was Gen 5 Camaro similar idea. Hmmmmn
Probably not for me.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
12-31-2019, 09:33 AM | #10 |
Drives: 2018 SS 1LE Join Date: Aug 2018
Not a fan at all... Looks out of place with that lower body line going right into the middle of it. 3/4 the cost of the ACS rockers for Autozone looking, stick on scoops
05-27-2022, 07:30 PM | #11 |
Thank You for shopping at https://www.southerncarparts.com/201...ke-scoops.html
