11-24-2019, 11:02 PM | #1 |
Drives: 2019 Camaro 2SS Join Date: Mar 2019
How does climate control work?
I found a post about a year old with this same question, but no real answer. Dual climate controls can sometimes produce really different temps on each side, even with the same settings. Are there sensors in the car trying to measure whether the driver or passenger side needs more heat or cooling?
11-25-2019, 02:11 AM | #2 |
Drives: 2018 Chevrolet Camaro 2LT Join Date: Mar 2019
You turn the knob up one degree and it blasts hot air at you. You turn it down one degree it blasts cold air.
I think it must have some kind of infrared heat sensor as today the ambient temperature was showing as 35F with temperature set to 70F but it was blowing cold air. I think my body temperature was likely warm as I had just played hockey so it decided cooling was needed even though everything else was cold. I wish they had a climate control app on the infotainment screen so you could tell exactly what was going on and ideally set it to different modes like controlling the outlet temperature or just a heat percent like old dumb car heating systems. Whatever it does now often isn't what I want. |
11-25-2019, 07:44 AM | #3 |
Drives: 18 zl1 Join Date: Aug 2017
theres a temp sensor by your right knee that reads what is in the car itself (for the driver). I'm unsure where the passenger one is for the dual systems.
you set a temp, the climate control tries to get that sensor to the temp you set. It also has a sensor in the air stream to tell what temp the air is blowing, so it can determine if it needs to change it to match what it needs. There is also an option in the display that lets you change how hard the air will blow on it's lowest setting. of the 2 camaros I've had, they haven't been off hardly at all. I can set it to 72-74 depending on my mood, and it works fine everytime, even if my wife has her side on 78-79. however, you can influence that sensor with your own body heat if you are huddled up around it. |
11-25-2019, 08:30 AM | #4 |
Drives: Fast if no one's looking Join Date: Aug 2019
There are two sensors, on most cars they’re in similar locations in the lower half of the dashboard usually by the driver/passenger knees.
It works just about the same as the thermostat in your house. In the old days there was a mercury switch and the temperature slide switch was a rheostat. Today they use RTDs (resistance temperature sensors). There’s a damper inside the HVAC vents that adjust and mix the right amount of hot air from the heater core and cold air off the A/C evaporator that will continually adjust based on current readings (ambient cabin temp on driver or passenger side) of the RTD and temp settings for driver and passenger. Only difference between your home thermostat and the car’s is you have to manually switch from heat to A/C in your home. The car will run the A/C in all conditions unless you override it and turn it off or do not run the climate control in full auto mode. This is due to the fact that a car is a tightly enclosed environment susceptible to humidity. |
11-25-2019, 09:40 AM | #5 |
11-25-2019, 09:58 AM | #6 | |
that won't cut it in the car to me. if you set it to one temperature and let it heat or cool to it's desire, you'll wear equipment out because of the constant auto switching. you have to have a bit of hysteresis otherwise you'll never get it the way you want it, and neither will it. |
11-25-2019, 03:43 PM | #7 | |
Your car does. |
11-25-2019, 03:46 PM | #8 | |
11-25-2019, 03:49 PM | #9 | |
No car does this. No house does this. I mentioned it because if a car did do this, you'd still need the hysteresis of a few degrees, and nobody would be comfortable with that. I wouldn't be. |
11-26-2019, 09:32 AM | #10 |
Below is from the repair manual. It doesn't quite work like home HVAC. Cars often keep the A/C running all the time to remove humidity. They just route cooled air across the heater core to rewarm it. There are a lot of sensors in play here. Both left and right side of the cabin have upper and lower duct temp sensors plus there is the center sun load sensor. The A/C has an evap temp sensor and a refrigerant pressure sensor. Those are the basics. All the actuators for the dampers also have position sensors. DESCRIPTION AND OPERATION > AUTOMATIC HVAC DESCRIPTION AND OPERATION > HEATING AND A/C OPERATION The purpose of the heating and A/C system is to provide heated and cooled air to the interior of the vehicle. The A/C system will also remove humidity from the interior and reduce windshield fogging. Regardless of the temperature setting, the following can affect the rate that the HVAC system can achieve the desired temperature: Recirculation actuator setting Difference between inside and desired temperature Blower motor speed setting Mode setting When the A/C switch is pressed, the HVAC controls sends a signal to the HVAC control module via LIN-Bus. The HVAC control module evaluates this signal and sends an A/C request signal to the ECM via CAN-Bus. The ECM checks all preconditions before releasing and if all conditions are met sends a release signal back to the HVAC control module. The ECM will provide a ground for the A/C compressor relay enabling it to close its internal contacts to send battery voltage to the A/C compressor clutch coil. The A/C compressor clutch will be activated. The performance of the A/C compressor is regulated via a variable A/C compressor solenoid valve. The HVAC control module supplies battery voltage to the A/C compressor. When the A/C switch is pressed, the HVAC control module provides a pulse width modulation (PWM) signal to the A/C compressor solenoid valve in order to command the performance of the A/C compressor. The following conditions must be met in order to activate the A/C compressor: Battery voltage is between 9-18 V Engine coolant temperature is less than 124°C (255°F) Engine speed is greater than 600 RPM Engine speed is less than 5500 RPM A/C high side pressure is between 269-2929 kPa (39-425 PSI) Throttle position is less than 100% Evaporator temperature is greater than 3°C (38°F) ECM does not detect immoderate torque load ECM does not detect insufficient idle quality The ambient temperature is above 1°C (34°F) The sensor information is used by the ECM to determine the following: The A/C high side pressure An A/C system load on the engine An immoderate A/C high side pressure The heat load at the A/C condenser The air streams into the passenger compartment through the heater core and the evaporator core. The air temperature actuator drives the mixed air door to direct the airflow. If the interior temperature should be increased, the mixed air door is put into the position in which more air streams through the heater core. If the interior temperature should be decreased, the mixed air door is put into the position in which more air streams through the evaporator core. DESCRIPTION AND OPERATION > AUTOMATIC HVAC DESCRIPTION AND OPERATION > RECIRCULATION OPERATION The recirculation switch is integrated into the HVAC control. The selected recirculation switch position is sent to the HVAC control module via LIN-Bus. The HVAC control module controls the air intake using the recirculation actuator. In recirculation mode the recirculation door opens in order to circulate the air within the vehicle. In fresh air mode the recirculation door is closed in order to route outside air into the vehicle. DESCRIPTION AND OPERATION > AUTOMATIC HVAC DESCRIPTION AND OPERATION > AUTOMATIC OPERATION In automatic operation, the HVAC control module maintains the comfort level inside of the vehicle by any faster.controlling the A/C compressor clutch, the blower motor, the air temperature actuators, mode actuator and recirculation actuator. To put the HVAC system in automatic mode, the following is required: The auto 1. switch must be activated. The air temperature switch must not be in either the full 2. hot or full cold position. Once the desired temperature is reached, the blower motor, mode, recirculation and temperature actuators automatically adjust to maintain the temperature selected. The HVAC control module performs the following functions to maintain the desired air temperature: Monitors the following sensors: Ambient air temperature sensor Duct air temperature sensors Ambient light/sunload sensor Regulate the blower motor speed Position the air temperature actuators Position the mode door actuator Position the recirculation actuator Request A/C operation Control of the A/C compressor When the warmest position is selected in automatic operation the blower speed will increase gradually until the vehicle reaches normal operating temperature. When normal operating temperature is reached the blower stays on high speed and the air temperature actuators stays in the full heat position. When the coldest position is selected in automatic operation the blower stays on high and the air temperature actuators stay in full cold position. The mode actuator remains in the panel position and the recirculation actuator will remain in the recirculation position. Under cold ambient temperatures, the automatic HVAC system provides heat in the most efficient manner. The operator can select an extreme temperature setting but the system will not warm the vehicle any faster. Under warm ambient temperatures, the automatic HVAC system also provides air conditioning in the most efficient manner. Selecting an extreme cool temperature will not cool the vehicle Last edited by ctrlz; 11-26-2019 at 09:57 AM. |
11-26-2019, 11:01 AM | #11 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Question. I've always been told that running the heat with the A/C is bad for your A/C system. Is there any truth to that?
11-26-2019, 11:17 AM | #12 | |
In days before rear defrost was standard, if you had air conditioning in the car and turned the defog up and the temp to warm or hot it would defog everything pretty well. |
11-26-2019, 11:23 AM | #13 |
I don't think so, as this is now pretty commonplace, particularly with higher end auto-climate systems. It just happens behind the scenes. Even my 1990 Accord had a recommendation to (manually) run the A/C with heat in winter to assist in defogging the windows.
11-26-2019, 03:06 PM | #14 |
See my post right above yours
