08-07-2022, 11:54 AM | #1 |
Drives: 14 SS Join Date: May 2019
Ported throttle body
Does it really do anything for throttle response , and if so, should it be done before dyno tune?..
auto SS car , planning a cam upgrade ( A wee SS1 , if I get the race bug , I'll get a 415 short block) and want to know the PTB concensus yeah or neh , Thanks all |
08-07-2022, 12:07 PM | #2 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
I have no experience either way, but have seen this question a million times and everyone says they can feel a difference in response.
08-07-2022, 12:13 PM | #3 |
Drives: Car Join Date: Jan 2013
Yes. It improves throttle response significantly.
Yes. Get it before tune, for no other reason but that’s your setup before and after the tune. Recommend Nick Williams TB. |
08-07-2022, 12:16 PM | #4 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
I have a new in the box ported AC Delco TB that I'm going to sell soon.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
08-07-2022, 09:27 PM | #5 |
Started#gottalovethatblue
I have one of Bo's ported throttle bodies for years now. In an automatic it is definitely a must have. There's a noticeable improvement in throttle response. If you can get one ported by Bo, I highly recommend it!
08-08-2022, 08:13 AM | #6 |
Thanks guys, I'll pull the trigger on one!
Bo White, I'll pm you |
08-08-2022, 08:20 AM | #7 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
I second Bo’s Tb, I’ve had mine for about 3 1/2 years. It was the first thing I did when I got my car.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
08-08-2022, 09:26 AM | #8 |
Instagram: Sangstah
Ported TB definitely improves throttle response. Doesn't matter before or after tune as you don't need to retune for a ported tb.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
08-08-2022, 09:42 AM | #9 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
It's not necessary, but it's better with a tune.
A year ago I bought a TB from Soler Performance, uploaded a datalog and sent it Dynosteve for correction. He adjusted a couple of things and the change for the better is more than noticeable.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
08-08-2022, 12:12 PM | #10 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I got one of Bo's TBs years ago and it flowed so much air it went outside the parameters of the stock tune and threw it into limp mode. BTW, Bo was clear it could require tuning adjustments. Had the tune adjusted and it's worked perfect ever since. In other words, port the TB and then tune it.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
08-08-2022, 12:41 PM | #11 | |
08-09-2022, 05:09 PM | #12 |
I still have the VMAX ported TB I bought many moons ago. Before I got cammed and stalled, I had nothing but a CAI and the ported TB, and yea there is a signifcant improvement in throttle response!! I was really surprised at how much better it was over the stocker. One of the best mods I ever did in the beginning. No tune needed either. Been on the car for about 10 years now. If you can get one from Bo, do it. It is better than the VMAX one..
08-10-2022, 04:33 AM | #13 |
I would also like to add that even after the tune, the throttle response was still not quite as pleasant as I would have imagined. So I added a throttle body controller and only then was I satisfied.
But it is a question of the individual. Maybe just TB alone will be enough for you.
