Roto-Fab
Old 05-20-2018, 10:33 PM   #29
TheInfamouSS
@LS.ACE
TheInfamouSS's Avatar
Drives: 2014 Chevy Camaro 2SS/1LE
Yea, I had a battery go bad after only two years in my car. Factory battery. Had to change it. Sometimes it happens. Worth trying.
TheInfamouSS is offline   Reply With Quote
Old 05-20-2018, 10:39 PM   #30
427K
427K's Avatar
Drives: 15 1SS 1LE
That type of symptom is a grounding, or loose connection issue.
Check the connection on the relay box that connects to the starter relay it might be loose.
I spent most of my money on beer and cars, the rest I just wasted.
427K is offline   Reply With Quote
Old 05-20-2018, 11:24 PM   #31
SharpOldNo7
SharpOldNo7's Avatar
Drives: 2015 2LT RS Convertible
Remove the starter and clean the mounting area on the engine block where the starter mounts. Clean the open end of the started housing. Remount the starter. Try to start. If problem persist, clean both ends of all ground cables and straps. I had the same problem on my superduty.
SharpOldNo7 is offline   Reply With Quote
