Vararam
Old 11-27-2016, 10:51 PM   #43
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Originally Posted by Homeless Man View Post
Anyone else agree with that guy that I should get the heat shield wrap that's adhesive vs the other one we were talking about in this thread?
Both will help about the same ,it's your choice if you want to use a blanket or adhesive mat/tape
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 11-28-2016, 12:57 AM   #44
MrChrisLS3
Drives: 2018 1SS M6
I would think the Velcro wrap would be better should you have to remove the starter for any reason. Seems like a permanent wrap might make the starter more difficult to handle. I could be wrong though.
MrChrisLS3 is offline   Reply With Quote
Old 11-28-2016, 07:39 AM   #45
Dmpsix
Dmpsix's Avatar
Drives: Black L99 2SS/RS
Your headers aren't coated right?
Dmpsix is offline   Reply With Quote
Old 11-28-2016, 08:11 AM   #46
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
I'm a coated header fan.
Mine has 115k on it and the uncoated headers have been on for 100k. Mine has been hard starting for about 20k miles when it's hot. I'll keep it till it dies I guess lol.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 11-28-2016, 12:37 PM   #47
Homeless Man
Homeless Life Chose Me
Homeless Man's Avatar
Drives: LS3 (sold 4/21)
No they're not. So coated headers make that much of a difference in heat? I'll keep that in mind for the future.
Pity a man in familiar places, who yet feels like a stranger.
Homeless Man is offline   Reply With Quote
Old 11-28-2016, 02:45 PM   #48
Homeless Man
Are u guys sure this one fits our starter?
Old 11-28-2016, 04:02 PM   #49
davidscamaro
It diameter is 24" so you should have plenty of coverage, probably even bit too much for the smaller LS starters. I'm sure you can use steel cable ties to secure it tight if the over lap passes the velcro
Old 11-28-2016, 04:06 PM   #50
davidscamaro
The starter in the pic appears to be a SBC starter that are bigger than LS starters ,but like I said steel ties will secure it no problem if you have to over lap the blanket
Old 11-28-2016, 04:07 PM   #51
Candr3535
Candr3535's Avatar
Drives: 2013 ZL1 Triple Black Vert M6 #5591
I got it it fits, lil long so cut it to fit and then if u want to tie it for better security than do so.
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice..
Candr3535 is offline   Reply With Quote
