07-12-2016, 11:35 AM | #29 | |
I'm not reffering to track driving. But yes spirited driving. And the Hydroplaning/waterski issue was because of DD. He said he DD the car. You don't want to have a setup you Don't want to drive |
07-13-2016, 06:27 PM | #30 |
07-13-2016, 07:04 PM | #31 | |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
07-13-2016, 08:54 PM | #32 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
So I should air these up at 50 psi or a little less?
Edit: well I looked it up and it seems I should still go by the door jam which would be 36 psi even though it's a different setup that doesn't change.
Pity a man in familiar places, who yet feels like a stranger.
07-14-2016, 12:27 AM | #33 |
I havent had an issue with my 315/275 set up, I have pushed it in turns with of course the gf screaming on my side to slow down which in courages me me to go faster, and the overall feel to me is a lot better than the stock set up, and I have also driven the car in a down pour and the toyo proxies 4 plus tires did awesome, so in my opinion would I have done a different size or tire now no way
Cai intake and a few other mods😎
07-14-2016, 01:48 AM | #34 |
How much air u guys putting in 315/275 setups?
07-14-2016, 02:14 AM | #35 |
Drives: 2018 1SS M6 Join Date: Nov 2014
You'll want to go with the door jam pressure. The 50lb or whatever on the tire is the max volume of air the tire can hold, it doesn't account for load.
I'm not so sure about wider fronts creating more understeer. Although they will increase the amount of force needed to turn the steering wheel. The wider rears may make it seem like there's more understeer because it will reduce oversteer, which is a tactic used to reduce understeer. The wider fronts will not reduce the turn circle in slow driving parking lot situations. You may however experience some wheel skipping in those situations. Wider tires will also make you more susceptible to trammeling, or the tires catching the grooves on the street. As far as wet driving, it is wholly dependent on the tires ability to push water out from under it. Some are better than others, I suppose. Save your skinnies if you do any driving in the slushy stuff. A wide tire, all season or not, is less effective in snow and slush. |
07-14-2016, 02:27 AM | #36 |
Drives: 2015 AGM 1SS Join Date: Nov 2015
36 Psi for my P-zeros 315/275
1" Hotchkis drop springs|315/275 P-Zeros on polished MRR 228 wheels | Rear bow-tie delete | Front AGM bow-tie| IOM "SS" emblems | NPP and 93 Octane Fuse pull.
07-14-2016, 04:31 AM | #37 |
Drives: 2011 Camaro 1SS Join Date: Feb 2016
35-37 here
2011 SGM Camaro 1SS/RS A6 - Vengeance Racing built/tuned. 590RWHP/560RWTQ, ADM LSA Conversion, 2.5 Grip-Tec, ZL1 fuel pump, ADM FPCM, FIC1000, VRPD2 Cam and LS3 Conversion with all the internal goodies, American Racing 1 7/8 Headers, no cats, SW Retro Cat Back, ADM Intake, AFCO HX, Varimax Pump, Rotofab Reservoir, B&M Transmission Cooler, VMAX TB, Elite Engineering CC, BMR LCAs, Trailing Arms, Toe Rods, DSS 1000hp axles, ZL1 Bumper and Sideskirts, Night Owl Halos, Matte Black 20" Rohana RC-22 with 20x10-275s/20x11-315s, R1 Concept Premier Drilled/Slotted Rotors, Hawk Ceramic Pads.
07-14-2016, 06:09 AM | #38 |
INJACC
Drives: 2010 CGM 2LT/RS AUTO Join Date: Jan 2009
I have the same set up 275/40R/20 & 315/35R/20 and I take corners real fast without hesitation. No problem in the rain too...
Tire pressure for me is 34 - 36 My car also is lowered and I love the look as well as everyone else too Enjoy your set up
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty CAI - Cold Air Inductions / VMAX TB / Trifecta Tune Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels / Oracle Afterburners / Oracle Concept SMD Side markers Complete SS Brembo Brakes Set |
07-14-2016, 07:58 AM | #39 |
Drives: 2010 Camaro SGM 1LT M6 Join Date: Jan 2015
Running anywhere from 35-37lbs. 38lbs shows up on hot days sometimes.
Arkentect's Build Thread!! - UPSTATE C5 MEMBER
2010 SGM M6 1LT - SOLD Current - 2009 C6 Corvette Z51 |
07-14-2016, 10:10 AM | #40 |
Drives: 2018 Charger SRT 392 F8 Green Join Date: Aug 2010
I run mine at 36 cold on all 4 corners. I have the 275/315 set up as well. Just recently changed the rear tires to the nitto NT05 from the invos. Still running the invos up front. The rear invo's were good but the NT05's are much better in the grip department but sacrafice's some mileage. The front invo's still have lots of life in them and they have great steering response, solid side wall feel and grip really well.
07-14-2016, 05:50 PM | #41 |
The meat is here 🍆😈
07-14-2016, 06:08 PM | #42 |
Drives: 2014 SS Join Date: Aug 2014
