03-08-2016, 08:33 AM | #57 |
Just got approval for a test set to go on an MRC car. Will just have to line one up and see what we can make happen!! Stay tuned!!
03-08-2016, 01:15 PM | #58 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
03-09-2016, 12:22 PM | #59 |
Drives: Varies Join Date: Dec 2009
I got my springs today! I am installing them TONIGHT!
1ss, MRC, NPP lets see what happens... also have some 25mm spacers to go all around. |
03-09-2016, 01:18 PM | #60 |
03-09-2016, 04:39 PM | #61 | |
Drives: 16 Camaro SS Join Date: Jul 2012
It's like election night.
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
03-09-2016, 05:39 PM | #62 |
SABIO
25mm.....that is quite the push out.....
Flush with fender is abour 18 - 20 mm
03-09-2016, 07:24 PM | #63 |
25mm is a full inch
03-10-2016, 03:52 AM | #64 | |
Drives: 15 Silverado, 15 Corvette 2LT Z51 Join Date: Aug 2012
I'd get a P.O box in the nearest US City and have them delivered there, unpack and put the springs in my trunk.
2016 Camaro 2SS Mosiac Black Aka-The Reaper
Build Thread- http://www.camaro6.com/forums/showthread.php?t=440437 |
03-10-2016, 11:48 AM | #65 |
Report!
In short the springs do not work with MRC. I have emailed Phastek directly with my findings. The front springs are the ones that do not work. I did install the spacers, and with alignment, it looks pretty good I think. It would of been perfect if the springs worked! The reason I went with 25mm, is that these are spacers that have studs off of them and I did not want to have to trim the factory studs to be able to go into the pockets in the back of the OEM wheels. 20mm was the next lower option and I think the oem studs would of hit in the wheel pockets. |
03-10-2016, 12:09 PM | #66 |
What was not working with the fronts? perch, mounting plate?
03-10-2016, 12:40 PM | #67 |
03-10-2016, 12:41 PM | #68 | |
From what I can tell the top of the spring and the top of the mount are different between MRC and Non-MRC cars. We are going to get it figured out!! |
03-10-2016, 01:05 PM | #69 |
I figured that there might be a difference between the two. It will be just a different set for the MRC cars. The way I see it, there should not be a problem with the ride height of the car. What happened when I put some weight in the trunk that lowers the rear for one inch? The MRC should still work as normal.
03-11-2016, 07:15 AM | #70 |
Drives: 2016 2SS Join Date: Nov 2015
Tags |
camaro springs, lower, lowering springs, phastek springs, springs |
