Old 03-30-2015, 10:46 AM   #1
Homeless Man
Homeless Life Chose Me
Homeless Man's Avatar
Drives: LS3 (sold 4/21)
Question CEL & Longtube Headers Question
I know check engine light comes on with longtube headers and highflow cats which is what I installed the other day (stainless powers). But usually people say it takes a little bit. I think mine came on right when I started it or shortly after. I did have to buy a rear O2 sensor for 1 cat. It was that Bosche smart link and you have to cut the connector off the original sensor. It seemed sketchy so maybe that one sensor isn't connected right?
Btw this is the video of how to connect old O2 to the new one:
Pity a man in familiar places, who yet feels like a stranger.
Homeless Man is offline   Reply With Quote
Old 03-30-2015, 10:53 AM   #2
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
It doesn't matter how it's connected or if it's not connected at all...the end result is the CEL...you wasted money buying a rear sensor that's obsolete with the headers....READ
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 03-30-2015, 11:08 AM   #3
Homeless Man
Chill I have high flow cats and needed to plug up the hole anyways.
Old 03-30-2015, 11:34 AM   #4
BenningJ
BenningJ's Avatar
Drives: 2013 AGM 1SS/RS LS3
You need to get a tune. When I installed my headers, I had previously done a dyno run (398hp/405tq) and when I finally went in to get the dyno tune done with the headers my baseline was way off. It showed 402hp/380tq and my fuel trims were way rich. Once everything was dialed in it was 425hp/411tq. Bottom line: Get the tune done.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts
BenningJ is offline   Reply With Quote
Old 03-30-2015, 11:36 AM   #5
SoMaR
Drives: 2023 Camaro ZL1
I'm dealing with the delayed response code with my Kooks and green cats. I had to replace the bank 1 upstream O2 sensor. Trying to figure out how to get this to stop coming on until I get tuned. From what I understand that cide won't hurt the car
SoMaR is offline   Reply With Quote
Old 03-30-2015, 12:41 PM   #6
Homeless Man
I am getting a tune thats not what this is about. And u can't keep it from coming on.
Old 03-30-2015, 04:01 PM   #7
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
the rears get tuned out , when you get a tune . rear O2's don't even need to be pluged in after a tune. If you want to replace the rear o2's , use direct fit O2's.
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 03-30-2015, 06:38 PM   #8
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
OEM sensor for rear are about $35 on amazon. No worrying about cutting and connecting. I got my cel after about 400 miles, just cleared it with an elm27 and torque app. I still haven't gotten the car tuned and the cel hasn't come back on yet. Once it does, I'll just clear it again until I get the car tuned.
760bowtie is offline   Reply With Quote
Old 03-30-2015, 06:43 PM   #9
Texas RattleSnake
Drives: 2013 Camaro ss/rs
So I'm about to install long tube headers. I didn't know that I don't need to hook the rear ones up? Just put the extender wires for the 2 front ?
Texas RattleSnake is offline   Reply With Quote
Old 03-30-2015, 06:47 PM   #10
760bowtie
760bowtie's Avatar
Yea the extensions are for the front sensors. Like mentioned above they rears will be turned off once you get a tune and the sensors will just serve as a plug.
Old 03-30-2015, 06:48 PM   #11
Texas RattleSnake
Okay thanks. Didn't know that lol
Old 03-30-2015, 07:47 PM   #12
Homeless Man
Wow what a waste of money then ($60)
Anyways so any of you have CEL come on immediately?
Old 03-30-2015, 08:04 PM   #13
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Whats the code? Were all just assuming its a O2 code, but have you pulled the code to make sure?
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 03-30-2015, 08:26 PM   #14
L99CAMA2011
L99CAMA2011's Avatar
Drives: One of the baddest handling Gen 5s
Rear O2s need to be plugged into the car not the exhaust.
L99CAMA2011 is offline   Reply With Quote
