09-03-2014, 10:07 PM | #15 |
Drives: 2013 ZL1 Join Date: Oct 2013
113 trap speed seems kinda low though.. What is your elevation there? DA?
2013 Silver ZL1
09-03-2014, 11:19 PM | #16 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
Guys I need to ask a real noobish question. Sorry I don't mean to jack the thread here but, I have never driven on the drag strip, so I don't have any real knowledge of what you mean when you say "slip the clutch" .......Without hijacking the OP's thread can I get a quick explanation?
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
09-03-2014, 11:21 PM | #17 |
It is letting out the clutch enough to where it starts moving the car but not completely out making the clutch solid.. Essentially it is exactly what is sounds like.. The clutch is slipping. It allows you to keep traction and not bog the motor when done right..
2013 Silver ZL1
09-03-2014, 11:24 PM | #18 |
Ok got it, and thank you. I need to get myself to the track! Sounds so fun! So much to learn.
Thanks again
09-25-2014, 09:51 AM | #19 |
Drives: Camaro ZL1 2014 M6 Join Date: Feb 2014
I asked this question on the "Drag Strip" thread but did not get an answer so maybe someone here knows. When all the nannies are off, which of the three ZL 1 suspension modes is activated? I have been launching in PTM 5 with "track" suspension mode but want to try launch without nannies. Does suspension mode matter? Can you select suspension mode when nannies are off? Any advice would be appreciated. 2014 ZL1 M6
10-04-2014, 06:35 AM | #20 | |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
10-05-2014, 06:10 PM | #21 |
Drives: 2014 custom blue ZL1 Join Date: Jun 2011
My updated time on the car is 12.46 @116mph. I run the same time with my tires deflated to 17psi and not deflating them at all. I keep my car in mode 2 with traction control and stability control off.
Custom blue 2014 ZL1. Cold air intake,clear bra,apex springs,apex oil catchcan,18 percent pulley,stainless works long tubes wit high flow cats,ls3 throttle body, (595tq/607hp) to the wheels
10-05-2014, 06:12 PM | #22 |
You go to test and tune today?
2013 Silver ZL1
10-07-2014, 11:15 PM | #23 |
If you can make it try and stop by Sonoma Raceway tomorrow 10/8 - Wednesday Night Drags !
10-07-2014, 11:17 PM | #24 |
I might see if I can make it out there too.. What time do gates open?
2013 Silver ZL1
10-07-2014, 11:27 PM | #25 |
10-07-2014, 11:28 PM | #26 |
Will do..
2013 Silver ZL1
11-15-2014, 06:22 AM | #27 |
Looks like you might have hit a 1.9X 60' and getting better. Mode 2 still has traction and stability on just not as much of it.
11-15-2014, 08:28 AM | #28 |
No I haven't been able to run my car because I got some new rims. To make a long story short I'm waiting for my extended studs before I run my car again.
