05-15-2021, 06:31 AM | #1 |
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10 Join Date: Dec 2017
Rear seat re install help
Hey guys, so yesterday I took out a cage (will be available for sale soon), from my newly acquired ZLE. After doing ALL the heavy lifting I am stuck with a relatively simple issue - but an issue nevertheless. The car had rear seats removed for the cage.
I am trying to re install the back seat rest (the top part). And for some reason the hinges are just not wanting to go back into their slots on the sides. From the looks of it - they are about 1/2 inch forward and therefore not lining up with the entry opening. I have tried to push the seat (as u can imagine there isn’t a lot of space in there), tried to lay it flat and push in, tried to stand it up and push down (which seems the likely way it goes in). I am sure I am not doing something right - before I get too frustrated and start to hammer away - I figured I would “call a friend”. Any help the community can provide would be helpful. Thanks |
05-15-2021, 11:57 PM | #2 |
Drives: '21 ZL1 A10 '08 SRT10 Join Date: Apr 2019
As I just removed an Reinstalled the seat. Mine just popped out and getting it in was just about getting it to the right angle.
2021 ZL1 A10 in Satin Steel Metallic, 2008 Viper Vert M6 in Venom Red, 2018 ZL1 A10 in Bumblebee Yellow (SOLD)
05-16-2021, 04:24 AM | #3 |
Thanks I’ll keep trying to find that angle thx
05-16-2021, 04:25 AM | #4 |
05-16-2021, 07:48 AM | #5 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Not sure if the SS (Vert) is any different than the ZLE, but the back goes in before the bottom in my case. There is (2) studs that the lower seat back has to slip onto and then nuts. Then the top clips in with the flat spring metal levers. That's even if it's the same? With you talking about hinges on the sides, I'm guessing its not. But I would think the seat back still goes in first.
05-16-2021, 11:30 AM | #6 | ||
05-16-2021, 04:27 PM | #7 |
Thank you for your help arpad - appreciate it!
05-16-2021, 04:28 PM | #8 |
I figured out the issue- the trim price was not installed properly and hence the seat was not going in - duh
05-16-2021, 04:47 PM | #9 |
What cage are you going to be selling.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
