05-13-2021, 09:35 PM | #1 |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Jun 2019
ZL1 bumper install
Got a respray on the bumper due to some rock chips and such and when I got it back, bumper looks good but i noticed a splitter end cap wasn’t positioned correctly. I figured the clips weren’t installed or some other minor issue and I fixed it myself. Then I got to looking and noticed the soft support “bar” (its plastic) behind the grills is a bit loose. I’ll likely have to remove the bumper to fix this, but before I did, I’ve been looking at parts diagram to anticipate the fasteners (found it) but can’t find any bumper mounting instructions. Anyone have a good bumper install sheet, website, or video? Thanks in advance.
05-13-2021, 09:58 PM | #2 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
Lethal Camaro has a decent front bumper removal video. The ZL1 bottom fasteners are a little different, but it is obvious.
05-13-2021, 10:03 PM | #3 |
Saw that but wish there was more detail on the soft crush support. It’s the best I’ve seen so far for sure
05-14-2021, 08:50 AM | #4 | |
aka BeastZL1
The soft crush support is just sandwiched between the cover and the crash bar. It is in there loose.
05-14-2021, 09:52 AM | #5 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
yea its normal for that to move around a bit
05-14-2021, 11:15 AM | #6 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
It is not attached, it rests on two supports on the grill. Like others have said it is sandwiched in between the bumper and the frame of the car/crash bar. It will move some.
05-14-2021, 11:31 PM | #7 | |
Appreciate knowing that. Thank you. Saves me from ripping it all apart! The lethalgarage video makes it seem more secure for sure. |
