05-13-2021, 12:02 PM | #15 | |
05-13-2021, 02:38 PM | #16 |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
Well, I checked pressures before driving it to work this morning.
Turns out, I had the rears at 32 psi each and the front at 34. I have lowered the rears to 28.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
05-13-2021, 02:42 PM | #17 |
Wish I did...I would like to lower mine.
2016 NFG 1SS A8
05-13-2021, 05:19 PM | #18 | |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Curious how many of you had your tires heat treated prior to putting them on the car?
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
05-13-2021, 11:49 PM | #19 |
Drives: 2023 LT1 A10 Join Date: May 2017
Are most of yall using the 305/35/20 on stock wheels? I run mine at 30 fwiw.
I ask because I just saw they also have 305/30s...
2023 LT1, A10, NPP, Tech, Recaros, BVFKQ6 (Ordered 6/24, TPW 7/25, Built 8/1, Picked Up 10/3)
Past: 2017 1SS A8, 1998 SS M6, 1995 Z28 M6 |
05-14-2021, 06:54 PM | #20 |
Drives: 2020 ZL1 Camaro Join Date: Apr 2021
My NT555RII's are stock size on stock wheels, 305/30 20. I run them at 28 PSI on the street.
2020 Camaro ZL1 A10
Hawk Performance ceramic brake pads Roto-Fab Big Gulp cold air E85 flex fuel Low temp thermostat Nitto NT555R2 drag radials Custom tuned by MTI-Houston |
05-15-2021, 10:27 AM | #21 |
SS runs taller tires then ZL1 but ZL1 runs wider. Since you have a SS I would go with the 295/35/20 555R2 on the stock wheel. I put the 305/35/20 on my stock wheels and it's a touch too wide but still works. I didn't realize they run wider then the previous gen 555r which fit the stock wheel about perfect. I will likely get the 295/35/20 next time I need tires.
2016 NFG 1SS A8
05-15-2021, 11:50 AM | #22 |
How low of a temp can u run these? Do u know the temps for damaging the tire or lack of traction? They’re summer only? 40*
05-16-2021, 11:36 PM | #23 |
No issues here in 40 degree weather.
2016 NFG 1SS A8
05-17-2021, 05:16 AM | #24 |
Drives: 2017 ZL1 Join Date: Jan 2017
I've had mine out at low as 45°F and they don't really complain, in fact they are better than the stock GYSC at this temp, LOL
09-29-2021, 08:11 PM | #25 |
Since the retune, I lowered my rears to 28psi cold and still spin. I may try 26 or 27. Again, these are on 17s.
09-29-2021, 10:09 PM | #26 | |
Drives: 2019 ZL1 Join Date: Mar 2019
They have to be hot.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
09-30-2021, 08:56 AM | #27 |
28 isn't low enough... you are going to have to get them down to around 23-24psi and heat them up a little for a launch. I see a 2 tenth difference on my 0-60 time and 2 tenth on my 60ft going from 28-30psi down to 23 psi.
2016 NFG 1SS A8
09-30-2021, 11:01 AM | #28 |
I had set them at 28 cold a couple days ago and as we get better weather finally i noticed today they were at 26 cold. How are they driving when going down to 23 cold? Guess that will appx 25/6 when hot? I don't want to drive around town with them too low if its gonna feel mushy.
