09-30-2020, 08:40 PM | #1 |
Drives: 17 krypton green 1le Join Date: Feb 2017
Ideal compression ratio for DI
I’m in Oklahoma and pretty much all I can get is 91 octane and no e85 even remotely close.
The heads I have coming have slightly larger chambers so I’m down a smidge from factory. I was thinking about going .040 or maybe even the .028 to raise it a little. But again I know I’m limited with 91 just don’t know how much with being DI. So what’s ideal with 91 pump for LT1? |
09-30-2020, 08:41 PM | #2 |
You could roll this into your cam thread because it’s based on your cam timing
09-30-2020, 08:52 PM | #3 |
I’ll admit to being a novice here but doesn’t cam timing affect dynamic cr? Which I believe you can play with that to make up for your static ratio? But where should I start with my static compression ratio for best results?
09-30-2020, 10:32 PM | #4 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
What 6spdhyperblue said....
Do you plan to run your motor? Then static ratio is kinda meaningless if you're trying to figure out true cr so you have an *idea* of what octane fuel you'll need. If you plan to just crank the motor over by hand and never run it, go with static cr as your base.
10-01-2020, 10:48 PM | #5 |
Did you talk about this with the company your getting the heads from? I wouldn't exceed the 11.5 ratio that the stock Lt1 comes with. GM builds the engines to work down to 87 octane but no one should ever run that in a 11.5 CR engine. I'd stay around the compression ratio.
10-02-2020, 08:18 AM | #6 | |
I also found a formula online to estimate dcr utilizing your scr and cam specs. https://uempistons.com/p-28-effectiv...alculator.html Factory LT1 including cam shows dcr of right around 10:1 Using the .040 gaskets and the GPI ss3 cam it shows dcr of around 9.8:1. Being that is 99% of factor spec it should probably be a decent mid range performer. Like you mentioned factory allows using 87 without damage and I could probably go with .028 for higher dcr with same cam or even more overlap on more aggressive came while still having good pressure. However so far GPI has said I’d have to fly cut. I plan to see if the thicker deck on these heads allow for anymore leeway for valve clearance. |
10-02-2020, 10:00 AM | #7 |
Dumb Ass Deluxe
^^ This sounds good to me. If you're around 99% of original DCR you should be fine.
At the end of the day, the knock sensors are going to tell you what octane this particular motor wants to be fed.
10-02-2020, 10:15 AM | #8 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I thought we have no way of calculating dynamic compression because we don't know true cam timing? We don't know true seat to seat timing on the stock cam and aftermarket cams don't release this info. So unless anyone has taken the time to degree several examples in their LT1's how do we know? I have heard dynamic compression has to be taken from seat to seat timing and not from timing at .050.
10-02-2020, 06:37 PM | #9 | |
However I’ve read that vvt goes from as advanced as Much as 8.5 at idle and as high as 22.5 retard somewhere higher rpm. (Anyone know these for sure? I had trouble finding consistent numbers). But with this dcr goes as high as 10.4 to as low as 8.4:1 Last edited by MeanGreen1LE; 10-02-2020 at 06:43 PM. Reason: Changed number |
10-02-2020, 07:08 PM | #10 | |
I used DynoSim to estimate the cam profile and therefore estimate seat to seat timing for the stock cam and my new TSP Stage 1/2 cam. According to what it says the stock cam intake valve closing is 46.2 degrees after bottom dead center, which yields 10.31 DCR. DynoSim estimates 61.4 degrees ABDC, which yields 9.98 DCR. I also have TSP ported and milled heads (.030) which I calculate my new compression ratio to be 12.25:1, but even with this it looks like I have lost about .3 points in dynamic compression even with milling. I am not sure how accurate DynoSim's estimate of the seat to seat cam timing is. I believe it just uses your normal advertised @ .050 duration, LSA, and lift valves and tries to curve fit it. There is a setting to change the unitless "cam acceleration ramp rate" but it appears you can estimate seat to seat without having to select a cam acceleration ramp rate value. |
10-02-2020, 07:39 PM | #11 | |
I failed to link this earlier that shows the formula. http://angryengineer.blogspot.com/20...ion-ratio.html I assume you used LT1 cam specs without any advance or retard? |
10-02-2020, 08:25 PM | #12 | |
https://www.onallcylinders.com/2018/...am-specs-more/ But thats the thing, does the stock cam have a built in advance or retard? or is it accounted for in those specs? I know the stock cam sits in a full advanced? or retarded? position and the cam phaser moves it only one way. I've never understood this, and I wonder if this is the reason I can't get the peak DynoSim numbers to align with the stock advertised HP and torque numbers for the LT1. |
10-02-2020, 09:53 PM | #13 | |
10-04-2020, 02:03 PM | #14 | |
I would be really interested in trying to use my VVT again with my 228/236-114 cam to see if I could improve idle combustion stability, and maybe get some more bottom end. But I have the zero degree lockout. |
