dave@hennessey
Old 05-26-2023, 03:29 PM   #1
jpennin217
Drives: 2010 SS IO wit IO interior
Help Koni Orange sway bar link mount is lower than stock.
I needed new struts on my 2010 SS. Bought the Koni Orange 8750 1105 left and right. The mount for the sway bar link is about 2 inches lower. They say they are OEM replacement but the sway bar link will not work. I assume I need a shorter one. Does anyone have any ideas on which one to order? I have looked and don't find one that talks about Koni. Thank you
Figured it out. I just had to take a moment and then I jacked up the other side to drop the mount down and it bolted right up.
I/O 2ss with IO interior. Ordered on 08/29/09
09/16/09 at 3000
09/30/09 at 3300 10/12/20
10/08/09 at 3400 10/12/2009
11/05/2009 DELIVERED..
jpennin217 is offline   Reply With Quote
Old 03-15-2024, 09:40 PM   #2
Crystal_Red_SS
Crystal_Red_SS's Avatar
Drives: 2012 Crystal Red Tintcoat 2SS/RS
How do you like the Konis? I'm getting some installed on my 2012 next week, and they are supposed to match up with everything and don't require modifications.
ADM cold air intake with scoop, Solo Mach XL catback exhaust, custom tune, Stainless Power LT headers, RX catch can in Crystal Red Metallic
Custom Grind Cam 222int 230exh .601"/.608 116*+4, TSP 25% UD Pulley w/ ACC Serpentine Belt, 160* Thermostat, Melling High Pressure Oil Pump,LS3 Conversion,C5R Timing Chain,Amzoil ZROD 10W30,NGK TR6 Spark Plugs, Professional Stage II Cylinder Head Porting Service (360+ CFM), Install by 510 Race Engineering
445 RWHP, 419 ft/lb tq
Crystal_Red_SS is offline   Reply With Quote
