10-06-2019, 07:14 PM | #57 |
Drives: 1LE Join Date: Sep 2017
Wish Optic Armor has front and rear polycarbonate replacements for us.
10-13-2019, 08:28 PM | #58 |
Drives: 2020 2SS 1LE Join Date: Jun 2011
11-04-2019, 10:08 AM | #59 |
The Mechanic
Drives: 1SS M Join Date: Dec 2017
I handled it and made new weight threads. First in track section them moved it to general.
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
11-28-2019, 09:07 AM | #60 |
Drives: 2016 1ss GPI built Join Date: Nov 2019
11-28-2019, 07:27 PM | #61 | |
I have CF doors that are empty, no glass no nothing. 18" lightweight wheels Hoosiers R7 and full roadrace cage and with 3/4 of fuel I am at 3470. 2900 is going to be a major accomplishment. |
11-29-2019, 10:38 AM | #62 |
Drives: 1LEs Join Date: May 2009
11-29-2019, 11:29 PM | #63 |
Will be removing AC compressor lines condenser. What's the weight savings, will report soon.
Katech aluminum flywheel soon too. Hopefully 45 lbs with those two. Racing Brake rear two piece rotors soon too. That's another 17lbs. Ditch suitcase muffler with thin walled straight pipe. That's another ~20lbs. Polycarbonate front and rear windscreens is another ~40. After that I really dont know what else there is. |
11-29-2019, 11:31 PM | #64 |
Set of Penski shocks with titanium springs
11-30-2019, 04:14 PM | #65 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
QA1 carbon fiber driveshaft?? 22.2lbs verses a 2SS A8 OEM of 24.8lbs
11-30-2019, 09:16 PM | #66 |
12-01-2019, 07:49 AM | #67 |
12-01-2019, 09:37 AM | #68 |
Lol
12-01-2019, 10:32 AM | #69 | |
BAMF SS
Or if you made enough power to actually break the factory one.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
12-01-2019, 10:59 AM | #70 |
Oh I saw the beefy-ness of the QA1 alright, because I bought in and did the install. I am making fun of myself for doing it and getting such minimal savings in weight alone. Certainly looking forward to some of the other bennies of the carbon piece for sure! With that I still believe the minimal weight savings does equate to something as well, regardless. As did the UDP.
