09-09-2020, 03:48 PM | #1 |
Craig
Drives: 2019 ZL1 1LE Join Date: Jan 2019
Canada - WTS: Soler Throttle Body and Throttle Controller
**BRAND NEW**
Ported stock Throttle Body off a 2019 Camaro ZL1 1LE 87mm ported to 91mm for a 6.2L SC LT4 Manual BT Soler Performance. FEATURES: • Optimized Active Contours with sonic flow nozzles • Porting Taper and Upstream Bore with Velocity Stack (Lip & Bore Reduction) • Greater Discharge Coefficient of Plate/Blade interface • 16 Ra Microinch, Diamond Polished Surface Finish (Lower Skin Friction) • Shaftless high-pressure side of the blade for Larger WOT Flow Area (91 mm Effective Bore) • Self-Cleaning Throat/Flow Gap • Dome and Thread-locked Screws • Made from Brand New OEM Parts BENEFITS: • Lower weight to power ratio at part throttle, for a more nimble/spirited driving experience • Linearization and smoothing of the curve for a more predictable response and crisper shifts • Immediate response right off idling while keeping idling function undisturbed (No Hesitation/Stumble) • Does not require tuning. Warranty safe. • More air/power at every single throttle position after idle. Crucial for starting or expanding power gain modifications • Easy Installation (15 Minutes or Less) Also a Soler Performance Throttle Controller for a 7th Gen Corvette, 6th Gen Camaro or CTS 3 FEATURES: Five Modes, with a total of 37 possible settings EC Mode (Economy): Nine settings for improved fuel economy in city/hwy driving. OE Mode (Orig. Equip.): Same as stock ( One setting). CF Mode (Comfort): Nine settings for comfortable driving, all slightly more responsive than stock. SP Mode (Sport): Nine settings for spirited driving, with setting SP.5 giving a quasi-linear response when used with our throttle bodies. LU Mode (Ludicrous): Nine settings for very aggressive acceleration, for track use only. Compact LCD Display (2” x 1 .25” x .25” ) with white characters. Aluminum case and buttons. Fail-safe vehicle specific design. BENEFITS: Controls pedal sensitivity, allowing driver to adjust an otherwise widely considered non-linear (slow/spongy) pedal response/map. Increases the sensation of acceleration/power, very important for driving pleasure in finely tuned sports cars. Complements performance Throttle Bodies in achieving total throttle control as a system. Plug-and-play modification. Warranty safe modification. Easy installation (15 min, no tools or special skills required). Asking: Throttle Body $525CDN Throttle Controller $150CDN OBO ** Located in Ontario Canada ���� **
09-11-2020, 09:19 PM | #2 |
Craig
Bump
09-16-2020, 10:59 PM | #3 |
Craig
Bump
09-20-2020, 08:45 PM | #4 |
Craig
Still up for grabs, BRAND NEW NEVER USED
09-29-2020, 12:35 PM | #5 |
Craig
Bump
10-04-2020, 01:45 PM | #6 |
Craig
$600 CDN for the 2
