02-09-2021, 11:42 PM | #1 |
Drives: 2022 Chevy Camaro 2SS Redline Join Date: Dec 2016
Radiator Overflow Hose Must be leaking! Where do I find a replacement part from?
I have been dealing with my 2011 Chevrolet Camaro 2SS radiator overflow hose slowly leaking. For at least the last 4 months. The reason why is because I can not find a replacement part to resolve the problem. The part has been discontinued from the manufacturer GM.
2011 Camaro 2SS Overflow Hose - GM Part ID: 22756186 Discontinued. Can anyone on the forum help me find a suitable replacement part online that would work to fix my problem? The leak puddles up in one area only thus far. I don't think the radiator neck or body is cracked. The GM overflow hose is very specific by the design. It is built specifically for the 2011 Camaro 2SS. The hose also has a lid top cover built on it. The lid cover purpose is to protect the overflow coolant reservoir from getting dirt and environmental contaminations inside the radiator fluid. I saw other GM overflow hoses for a 2012 Camaro 2SS. I'm not sure if that would fix this issue. Because those hoses are made specifically for each year. GM made slight changes to the Camaro 2SS from 2010 through 2015 I need to get this problem resolved before summer hits. I know AutoZone and NAPA sell radiator hose types. I've looked into those also. They don't seem to correctly fix the problem because their either to wide, big, thick, or to small. The aftermarket hosing won't have the protective cap lid cover on the hose. If the overflow coolant reservoir is not completely covered up. This would allow for dirt and environmental contaminates to enter. Should I look into the option of replacing the entire hose and coolant reservoir completely with an aftermarket version that can mount onto the radiator? Who would have this specific part in-stock? Is there a company that reproduces parts for said year, make, and model besides GM? I really want to stick with the original parts. Last edited by Camaro_Fuzion; 02-10-2021 at 12:45 AM. |
02-10-2021, 06:03 AM | #2 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Mishimoto radiator hose set I think comes with all 3 hoses you can check them out.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
02-10-2021, 08:44 AM | #3 |
^^^^ this is what I did, just replace them all, doesn't cost much.
02-10-2021, 05:38 PM | #4 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
02-10-2021, 07:23 PM | #5 | |
Best bet go to local parts store and just get a hose the same size and make your own
02-10-2021, 08:32 PM | #6 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
I just took mine off. You’re welcome to it
02-11-2021, 06:53 AM | #7 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Take it off, measure the length and get some from the local parts store off their bulk roll.
02-11-2021, 11:34 AM | #8 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Problem with parts store hose is it wont have the little grommet that ‘seals’ it to the overflow tank so it will be a little more open than it is now
OP are you sure the cap isnt leaking?? Looks like it could be
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
02-11-2021, 12:29 PM | #9 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Am I the only one concerned with that coolant color?
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
02-11-2021, 01:01 PM | #10 |
02-11-2021, 01:03 PM | #11 |
02-11-2021, 01:13 PM | #12 | |
Exactly, the OEM GM hose comes with the grommet seal to cover the overflow tank. I'm trying to stick with the same parts used or new. |
02-11-2021, 01:15 PM | #13 |
02-11-2021, 09:18 PM | #14 |
