03-12-2020, 07:31 AM | #1 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Tire pressure
Hey guys. I'm heading to Talladega Gran Prix this weekend for a 1/2 day track session. What cold tire pressure do y'all recommend that i start with, and what pressure should i dial in once the tires warm up? I've been targeting 32 psi warm. Which seems to work well with the Goodyear Supercar3's.
Baby Blue
03-12-2020, 11:25 AM | #2 |
28-30 to start
03-12-2020, 12:37 PM | #3 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
34-35 Hot should be the target. I'm not sure if that is 32 warm. 27-28 psi cold should be about right.
03-12-2020, 09:13 PM | #4 |
ditto...27-28 psi cold is a good start. Keep the pressure monitor on the info screen during your runs!
04-12-2020, 10:35 AM | #5 |
Drives: 19' ZL1 1LE Join Date: Nov 2015
What kind of times do you guys run at TGP?
04-12-2020, 02:42 PM | #6 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
I'm sure you track guys have things dialed in, but at least for me for canyon carving and street driving, I find 33 PSI cold to be about perfect, anything less than that and you lose a little crispness in turn-in and the car just feels a little sloppy at times. With those pressures when I am running it hard up a canyon, I get to 37-38 PSI HOT and the car feels solid.
I would expect though that track driving would heat the tires even more, so I guess that is the reason for the lower starting pressures. Mine had been in that range before (from being lazy and not adding air over time), but when I do and go back up to 33 PSI cold, it feels like a different car in responsiveness and a general feeling of being lighter on its feet with less tire roll over when cornering. One thing I was just thinking about too, is even with starting with less tire pressure, you will never gain that crispness back, even as the temps. rise from heat. Heat will increase the pressure in the tires, but not because of air volume, rather by air expanding. So a tire cold at 33PSI, will still feel more crisp than a tire that starts at 28 PSI and is at 33PSI hot.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
04-12-2020, 07:20 PM | #7 | |
Lover of Speed
Drives: 2018 ZLE Join Date: Feb 2016
As for you comment about pressure and PSI...I am not a super smart science guy but that is wrong data. Volume is a factor of temp. So whether you are at 33psi because of heat or 33psi because of more volume, the pressure is the same. So a tire inflated to a hot 33 or cold 33 will still be under the same pressure which will give the same performance. But like i said, I am not a physics or thermodynamics expert but went to school with several of them, so I may be wrong, but willing to be educated.
Killer Whale Racing
2021 One Lap of America Track Videos 2019 One Lap of America Track Videos 2017 One Lap of America Track Videos 2022 Ram TRX 2018 Camaro ZL1 1LE 2020 Range Rover Sport SVR (Sold) 2014 Grand Cherokee SRT (Sold) 2014 Camaro Z/28 (Sold) |
04-13-2020, 11:03 AM | #8 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
Every tire is likely different, but I just use Chevy's track supplement for my OEM GY 1LE tires...28 cold to target 37 / 39 hot pressures (front/rear) for the track.
It will be near impossible to get that high on the street, so it makes sense to start with a higher pressure. Excess tire wear if you drive on low pressure tires too on the street.
04-13-2020, 11:22 AM | #9 | |
aka BeastZL1
TRZ06,
The difference is at the track you are constantly at the grip threshold of the tires. What feels good on the street isn't applicable to the track running ten/tenths of the limit. It may "feel" better, because the additional tire pressure is stiffening the dampening that the tire does. You get a stiffer ride, but you are also getting a smaller contact patch. This may be an acceptable compromise if you are NOT at the max traction threshold of the tires. I stand by my recommendation of 27-28 psi cold and 34-35 hot at the track. This is similar to the GM High Performance Supplement for Road Course cold starting pressures (ZL1 1LE 26 psi, ZL1 28 psi.) Quote:
04-13-2020, 02:09 PM | #10 | |
Current:
04-13-2020, 03:24 PM | #11 |
Drives: 2019 SS 1LE Join Date: Jun 2018
I found 34-35 hot to be the ideal pressure. Over 36 and I’ve found them to get greasy. Where to start cold has a lot of variables, but 28 should get you in the ballpark and adjust after a session.
04-13-2020, 07:06 PM | #12 | |
Drives: Chevy Camaro Join Date: Nov 2019
04-15-2020, 11:04 AM | #13 | |
Drives: gas powered Join Date: Jan 2019
Same for street spirited driving. Most sensitive tire air pressure wise I ever owned and I been buying 200 TW tires since the mid 90's. 36 over your out of the ball park.
04-15-2020, 02:35 PM | #14 |
My tire pressure readouts in the display are always 1lb lower than what I set them at using my accurate dial gauge.
Current:
