01-17-2020, 08:34 PM | #1 |
Drives: 2019 Camaro ZL1 // 1LE Join Date: Jan 2020
Looking for a Anti-Sub strap mount
I just installed a Brey Krause harness bar for my 6 pt harness, but I cannot find an anti-sub strap mount anywhere. I am new to the Camaro arena, so any help would be awesome. I plan to keep the stock seats and feed the straps between the seat bottom and seat back. That's how I did it in my C7 Z06.
01-18-2020, 02:33 PM | #2 |
Drives: 18 Black ZL1-1LE Join Date: Jun 2017
Garage therapy has a bracket
GT Sub Harness Bars Another option is the Schroth ASM harness systrm with anti submarining ASMŪ ANTI SUB MARINING TECHNOLOGY The patented SCHROTH asmŪ system offers an unique safety advantage for 4-point harnesses. asmŪ is the acronym for anti submarining. The risk to submarine (sliding underneath the lap belt), a well known phenomenon during frontal impacts, is significantly reduced by the asmŪ safety system. The energy converter is located in one of the shoulder belts. Severe injuries or death are possible using 4-point harnesses without the SCHROTH asmŪ safety system or an anti-sub strap. SCHROTH harnesses designed for use on public roads (FE push button models) or those likely to be used as 4-points come with the asmŪ safety system. The performance of the SCHROTH asmŪ safety system has also been positively tested in conjunction with airbags. Current Head And Neck Supports (HANSŪ) provide further reduction of head deceleration and neck bending. The asmŪ system on all SCHROTH Rallye and QuickFit belts - excluding the new QuickFit Pro - is not compatible the with HANSŪ. Only belts having a center RFR Cam lock can be used with HANSŪ. We recommend that only non asmŪ belts be used in competition harnessbelts. Racing harnesses without asmŪ must be worn with an anti-sub strap! Last edited by Repman; 01-18-2020 at 02:43 PM. |
01-20-2020, 11:28 AM | #3 |
Drives: 1985 Oldsmobuick Join Date: Oct 2012
What Repman is referring to is the Profi ll ASM 4 point harness which you can find here:
https://competitionmotorsport.com/sc...waAocUEALw_wcB If you were to use a 4 point harness, its the only one you would want to use. If you do want to run a 6 point harness with the stock seats, then you would have to run the Teamtech ASR which you can find here: https://teamtechmotorsports.com/shop...s/asr-harness/ I currently use this in my Viper with the stock seats and the two bottom straps come up from the bottom to the front of the bottom of the seat. |
03-29-2020, 09:36 AM | #4 | |
Hunting for another ZL1 1LE
Stohr F1000 - formula car fun 2022 R1T 2015 Macan Turbo Gone-2017 991.2 Turbo S Gone-2018 Raptor, tuned, leveled, tires/wheels Gone-2019 Camaro ZL1 1LE...track toy... Gone-2010 Camaro SS, built NA monster... |
