11-15-2019, 04:31 PM | #1 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
ZLE front ride height adjustment
Have any ZLE owners with significant track time lowered the front ride height to the lowest setting after track experience with it at default (middle) height?
If so can you share your perceptions or any measurable effects like lap times? My understanding is the main benefit may be an increase in the surface angles and resulting downforce from the front splitter, canards and rear wing. You also get a lower center of gravity in front where most of the weight is. I'd like to lower it, but I'd prefer not to worry more about scraping the front end. If it makes a difference I'll probably do it. |
