07-30-2015, 02:08 PM | #1 |
Drives: Black Camaro Join Date: Sep 2014
Your advise needed
There are some "famous" issues with the 2010 that I read amongst the discussion on this forum.
My 2010 LS3 Camaro engine with 40k miles is now having some oil leaks around the oil pan/oil cooler area, and coolant leak @ the driver side cooler hose to engine block fitting area. Is there any reliable shop/dealer around Los Angeles/Orange County, who worth the recommendation from you , I would like to hear it. Thanks. |
07-30-2015, 02:30 PM | #2 |
Drives: Supercharged 2013 AGM 2SS/RS Join Date: Oct 2013
I've had good experiences with Camino Real Chevrolet if you are looking for a dealer. Not sure what their prices are like outside of warranty though.
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports. 1967 Bolero Red 396 SS/RS Convertible |
07-31-2015, 03:47 AM | #3 |
Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
Heard a lot of good experiences from Camino Real but never used them. The oil cooler issue I believe was a recall issue so that should be covered, if not there was a 5yr/100k mile power train warranty for the '10's as long as you aren't too heavily modified you should be ok.
Haven't seen the coolant one before.... Sent from my iPhone using Tapatalk
UNDER CONSTRUCTION......again......
07-31-2015, 10:19 AM | #4 |
Drives: pleather and Chiclets Join Date: Mar 2012
I think the oil was a TSB, CMS fixed mine in ~2011. Only other times I have seen (see seen not read on Internet) coolant issues on the 5th gen was a cracked radiator where the two materials meet.
Good luck with camino real, they have lots of happy customers around these parts.
07-31-2015, 08:48 PM | #5 |
07-31-2015, 08:53 PM | #6 | |
Thanks for your input. |
07-31-2015, 08:58 PM | #7 | |
Thanks for chiming in. |
