Old 05-22-2020, 06:49 AM   #15
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Awesome looking pieces.
Old 05-23-2020, 12:11 AM   #16
Oak78
Drives: 2018 ZL1 1LE
Noonan Racing makes a 6 bolt billet LT block. Apparently LME has done a few builds with them using CID heads.
Oak78 is offline   Reply With Quote
Old 05-23-2020, 07:44 AM   #17
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Beautiful heads.
Darin Morgan likely had a hand in the design of those. He’s knows his stuff for sure. Mast has great products that deliver. Nice choice and looking forward to the rest of your build.
Old 05-23-2020, 10:43 AM   #18
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by Scottyz View Post
Beautiful heads.
Thanks fellas!
Old 09-07-2020, 09:54 PM   #19
MeanGreen1LE
MeanGreen1LE's Avatar
Drives: 17 krypton green 1le
Black label head setup
Thanks fellas!
Was researching heads and was positively influenced by your post. Found them on sale and could not resist!
Any hiccups with installing them? What pushrod length etc?
Thanks!
MeanGreen1LE is offline   Reply With Quote
Old 09-07-2020, 10:08 PM   #20
Joshinator99
Thanks!
So far, so good. But between fuel limitations and a crap ton of tuning time into it, there’s no way I’ll realize their potential this year. But with very little boost (11psi), I’m at 90 lbs/min of airflow. With another 30% blower speed left on the table, I’d say these heads are damn efficient!
You’ll need to measure up your pushrods once you decide on a lifter and start putting things together. With the increased deck height, the pushrods will need to be longer for sure.
Old 09-07-2020, 10:23 PM   #21
MeanGreen1LE
Thanks! I’m actually doing medium effort na on my 1le but you were the only one I’ve seen even mention them.
Thinking of going with slightly thinner gaskets since combustion chambers are bigger than factory head.
Old 09-08-2020, 03:55 PM   #22
Flowtie1
Drives: 2017 ZL1
Very nice, as you said Mast did some nice ls head work
2017 ZL1 M6 Silver Ice Metallic
Flowtie1 is offline   Reply With Quote
Old 09-08-2020, 04:29 PM   #23
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
How much airflow were you seeing on the stock heads?
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 09-08-2020, 06:26 PM   #24
Joshinator99
I don’t have a direct comparison unfortunately. I did cam, heads, headers, and more blower speed all at the same time (along with pistons, rods, etc). I was 76 lbs/min last year with stock cam, heads, manifolds, and 7.000/3.5000 pulley setup.
Old 09-08-2020, 10:06 PM   #25
KingLT1
KingLT1's Avatar
No biggie was just curious. I hit 84lb/min this weekend in 65-70 degree weather with the 3.375 on E64 and 19.5 degrees of timing.... I think after I swap to the Big gulp it will be close to 700whp...probably gonna have to drop the E content back a little more.
2016 NFG 1SS A8
