08-24-2023, 10:16 AM | #1 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Did or Do any ZL1s come with STB?
Talking about over the engine style.
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
08-24-2023, 10:59 AM | #2 |
Drives: 2023 ZL1 Convertible Join Date: Jan 2009
I have been investigating this for some time now... There is one thread on here somewhere that had pictures of a ZL1 with a factory brace installed. However, everyone says it wont clear the supercharger as I am sure you are aware...
Only the SS/LT1/RS/LT etc etc verts came with a brace..... Everyone says you do not need one, but I would certainly put one on especially on vert's. Always brings up the question if you don't need one, why do all the other model verts' come with it.. Jason
2022 Equinox RS
2023 Trailblazer RS 2023 ZL1 Convertible |
08-24-2023, 11:14 AM | #3 |
Shadow Gray '19 ZLE M6
Not to my knowledge.
The struts are braced to the firewall. Here is what Al had to say on the topic of strut bracing: https://www.camaro6.com/forums/showp...70&postcount=1
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
08-24-2023, 11:29 AM | #4 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
No coupe or convertible came from the factory with a strut tower brace. Only the convertibles have an x brace underneath since it is a convertible with less structure than a coupe.
As stated, the coupe doesn't need one. If you want one then you can get it but it'll be more for a cosmetic look. Unless someone takes their ZL1 out onto a road course and tests it with and without a tower brace. Then it's all stipulation on how much better the car will handle with one. Last edited by Vigilante375; 08-25-2023 at 09:42 AM. |
08-24-2023, 12:58 PM | #5 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
Here is the latest high perf version of this same ZL1 Chevy chassis platform with the LT4 installed, the CT5 Blackwing. They seem to think a beefy STB helps here despite probably other chassis stiffening changes on the CT5. Strut bars make a car stiffer, and on track stiffer is better.
I have the BMR STB, it fits perfectly and serves me well in heavy track duty. |
08-24-2023, 02:39 PM | #6 | |
Drives: 24 Sliverado 1500 ZR2, 2017 ZL1 Join Date: Feb 2021
Finally on the way to 1K.....
08-24-2023, 02:50 PM | #7 | |
Like I said, it's purely a cosmetic item at this point until someone takes a ZL1 (coupe) and tests it with and without a strut tower brace. Yes, it does help stiffen up the car for handling but if GM really thought the ZL1 needed it, then why didn't they put it on the ZL1 1LE? They liked the balance the car had without the brace. |
08-24-2023, 02:56 PM | #8 |
Drives: Chev Camaro 1le Join Date: May 2021
my 2018 ss 1le came with a brace from factory... its a coupe of course
08-24-2023, 02:59 PM | #9 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Here they are... painted RED in my case, which makes them at least 25% stronger
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
08-24-2023, 03:48 PM | #10 | |
To create an STB that fits the ZL1 and LT4 height they would need to redesign the existing standard Camaro STB and charge a little more or make less profit per car. They were already putting a ton of content and features into the ZL1 and 1LE at a very low price point to make the best bang for buck sports car car at the time, so I think they just decided it was great enough and they were done. |
08-24-2023, 07:36 PM | #11 |
Are you tracking this ZLE on road courses or is it more of a drag ZLE? Wondering due to choice of tire and other power mods which may result in heat. If you are running on road course, do the 345 R888R rub any even with wire harness moved?
08-24-2023, 08:03 PM | #12 |
Thank you Al Oppenheiser!
No and yes. No, all ZL1s, including the verts do not have a brace connecting the towers. But Yes they have all the same pair of 45-degree braces between strut towers and firewall.
08-25-2023, 09:52 AM | #13 | ||
But I believe that if GM said the chassis was to their liking after testing it, then why change it? The car handles well than more than 90% of the owners on here (to include myself) can ever imagine of pushing the car in any turn. |
08-25-2023, 11:28 AM | #14 |
