06-22-2022, 02:12 PM | #1 |
Drives: 18 ZL1 1LE Join Date: Apr 2013
Wideband Bung Location
I’ll be remote tuning my car & want to get a wideband bung welded onto my CSP headers before I have them coated. I’ll be running GESI cats so I was going to have a bung welded near the O2 sensor bung on the collector. Anyone have any clearance issues with the transmission in this location? My car is an M6. I have attached a picture of another car with CSP headers for reference. Thanks for any advice.
06-22-2022, 02:22 PM | #2 |
I did something similar by having a wideband O2 bung welded in before sending my headers off to be coated. Has worked out perfectly. I have an A8 though, FWIW.
06-22-2022, 02:29 PM | #3 |
Another auto car but that’s very close to where I put mine.
06-22-2022, 06:40 PM | #4 |
Thanks for the replies & pics guys. I’m pretty sure I’ll be fine in that location, but just wanted to make sure no one else ran into any problems there
07-01-2022, 08:55 PM | #5 |
I checked under my buddies manual car yesterday & there is plenty of clearance under there. I’m now thinking behind the O2 bung or on the car pipe itself. Does either of these locations seem better?
07-01-2022, 09:00 PM | #6 |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
2nd pic. you need to do it on an angle so the sensor doesn't make contact with the body. When I did mine on my '19, we had the car on the lift and welded it from underneath the car. Sure it's easier to do with the header off the car but having it welded with the headers on the car takes all the guess work out of the equation.
07-01-2022, 10:31 PM | #7 |
I agree on the 2nd picture too. I’d want to be as far upstream as possible. 10°+ angle for that bung is what’s needed.
07-02-2022, 06:11 AM | #8 | |
07-02-2022, 06:13 AM | #9 |
Thanks. I thought you would want to be a little further away from the merge on the collector so you’re getting a better mix from all banks? Yes, it will be at a slight angle up
07-02-2022, 06:38 AM | #10 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
I'm with you. I'd do the first pic for that very reason if there's clearance.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
07-02-2022, 09:06 AM | #11 |
Good thought for sure about the merge but your 2nd picture is further away than the narrow band. Mine has been fine and I can’t see you have any problem at all doing as shown in the 2nd pic.
07-02-2022, 06:01 PM | #12 |
Went with the location on the cat pipe before the cat.
07-02-2022, 06:57 PM | #13 |
Nice job! I ran a tap through the hole after the welding was complete. That gave me solitude knowing the WB wouldn’t try to become a permanent fixture due to distorted threads or debris.
Thread Tools | |
