04-16-2018, 06:04 AM | #1 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Switched 12V power source
Hey guys, I originally posted this issue in the DIY section but, thus far have not received any replies. I thought I’d try here as you guys are have undoubtedly run up against this issue when adding any electronics.
Here’s the deal: I installed a AEM wideband O2 gauge yesterday and despite searching for over an hour, I was unable to locate a switched 12v power source inside the car. All 12v wires I located were not switched. The voltage on every switched wire that I could find had been stepped down to 5 - 6 volts. I connected to a 12v unswitched wire and temporarily installed a jury-rigged switch under the dash so I could kill power to the gauge. Can anyone help me to locate a switched 12v wire?
Baby Blue
05-03-2018, 09:30 AM | #2 |
Drives: Overkill Supercharged 2016 CamaroV6 Join Date: Mar 2016
Yes Remove your center console its not that difficult under there you can tap into the harness I just tested for 12v on off there is also a grounding bolt right under there too makes the ground real easy I then taped and ran my wires out the back up into the dash and put wire connectors on the end so I can unplug and plug if i want to change it out. I believe I took some photo's of what I did Ill check my photo's and post. I am sure there are other sources as well but this is what I did and its clean cant see the wires and leaves options for further wiring as well.
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/ Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA Supercharged with Overkill Superchargers http://www.v6superchargers.com |
05-03-2018, 09:49 AM | #3 |
Drives: 2018 Hyper Blue 2SS convertible Join Date: Aug 2017
When I need a power wire for a accessory I use one of these.
https://www.tractorpartsasap.com/fus...QaArT8EALw_wcB
2018 HBM 2SS CONVERTIBLE A8 |
05-20-2018, 10:59 PM | #4 |
Add-a-fuse. I tapped circuit 42 and 44 and ran wires behind the wheel liner and went thru under the cab to get inside.
