07-27-2022, 02:56 PM | #43 |
The frontal pictures you posted of the LT1 and SS models suggests these ducts might have been deleted, but someone should take a picture of an LT1 inner fender to find out. I know that the SS Convertible (which is also NOT track rated like the LT1 is not) does not have the brake cooling ducts or auxiliary engine cooler ducts in the fender liner. Grille in the front bumper of a 2016 'vert also had block-off plates installed where the inlet ducts for the brakes and aux coolers would be on a track-rated car.
07-27-2022, 03:06 PM | #44 | |
07-27-2022, 03:11 PM | #45 |
Drives: 2022 LT1, 1981 320i Join Date: May 2022
Wait what? On my LT1 they are blocked off. Like they are there on the front bumper and if you follow with your hand they are block off as part of the fender liner, seems easy enough to remove/cut.
07-27-2022, 03:17 PM | #46 | |
Drives: 2020 Camaro LT1 Join Date: Feb 2020
If you live somewhere like in Florida sure but if I went with the 1SS I would have to buy a set of wheels and tires for the winter time when temps were too cold for the stock SS tires. For everywhere else in the US if you don't fully store it in the winter you would need to get tires and wheels anyway. |
07-27-2022, 03:20 PM | #47 |
I took my car to an autocross recently (EDIT: This weekend that just passed) didn't have any issues with brakes overheating. Track use not sure not many LT1s mine included don't really get tracked that I have seen really. Drag strips Autocrosses and twisty roads is where LT1s are more frequent from what I have seen.
07-27-2022, 03:44 PM | #48 | |
Electrical Engineer
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
07-27-2022, 05:06 PM | #49 | |
Thanks for correcting me on this |
07-28-2022, 07:23 AM | #50 | |
Electrical Engineer
07-28-2022, 10:43 AM | #51 |
Oh no, I wasn’t the guy that melted center caps and lost my brakes tracking the LT1.. I just misspoke about the LT1 having cooling vents in relation to the aforementioned topic. If there’s any tracking to be done, I’d be buying a 1LE.
07-28-2022, 03:20 PM | #52 |
Yeah no worries, I want to check out that you tube video you mentioned. At some point I will probably retrofit whatever is needed to get maximum cooling but right now the car is just a street car and I really like the brakes as is.
07-28-2022, 03:43 PM | #53 | |
Don't tread on me
Drives: 23 Sierra X31, Past 2017 Fifty 2SS Join Date: Nov 2012
07-29-2022, 07:58 AM | #54 |
Drives: 16 Camaro ss Join Date: Oct 2016
I just got it because it was a cheap lease ($300) and something to drive for 3 years. I wouldn't buy another one after the '17 I owned because I also had a lot of issues with it hence why I leased this time but I figured upgrading the brakes on the LT1 would be enough for it to hold it's own on the track but definitely not.
07-29-2022, 08:00 AM | #55 |
I wouldn't say everything sucks buck it's no 1SS. The seats are worse than my dad's Equinox seats and the interior is just plain. I understand this is a stripped model but FFS put some side bolstering in the seats at least up to what an Equinox has.
