07-27-2022, 08:31 AM | #29 | |
1LE (just to check it out, you never see them around here) What I can say for sure is the lighter weight, recent aggressive street alignment, wider wheels and stickier tires have made a huge difference in handling in the LT1…. It feels as, or perhaps even more stable as my ZL1 convertible, which of course is a bit softer than a regular ZL1 and a 1LE. I’m eager to take that test ride in the 1LE. |
07-27-2022, 09:19 AM | #30 |
Hold on a second here, didn’t you pull the stock high performance pads and replace with lower performance dusting pads? Maybe spent some time and a couple hundred bucks doing so? (which to me makes sense, I hate the dusting too). In the LT1, no dusting from the factory. Believe me when I say it, the car stops fine. I really can’t think of a time on the street that I’d need more braking power. I’ve intentionally pushed the car to test them (as best a reasonable and responsible). I just don’t think calling the rears crappy… is fair. Not as good, sure… but crappy to me means they don’t perform their intended function, which on the street they 100% do.
07-27-2022, 09:23 AM | #31 | |
It has the $750 gmpp drag brake from the factory for SS/Z cars
07-27-2022, 09:26 AM | #32 | |
2021 LT1, A10, RotoFab CAI, Flowmaster American Thunder axle back exhaust, JLT catch can, Katzkin leather interior.
07-27-2022, 10:23 AM | #33 |
Drives: 2020 LT1 Black Join Date: May 2013
Neither car is cheap by any stretch, its really more about how you plan on using it. After 7 years running on 6 cylinders I was just happy to finally have a torquey V8.
Anything with a 6.2L and 450hp is more than most pickups have...you'll get plenty of respect either way. |
07-27-2022, 10:53 AM | #34 |
Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
The good thing about the Camaro is that there are so many different variants. Something for almost everyone, including when it comes to V8 models. Having the ability to choose between basically three different naturally aspirated V8 models (LT1, SS and SS 1LE) is unheard of with most cars. So if you want a naturally aspirated V8 you get to choose which of those models best suits your needs/wants and your pocketbook. How lucky are we to be able to have so many good choices.
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) Last edited by ZPirate; 07-27-2022 at 12:32 PM. |
07-27-2022, 11:28 AM | #35 |
Drives: 16 Camaro ss Join Date: Oct 2016
I had a 2017 1SS with just intake and 6 pistons up front and now have a 2022 LT1 with E85, intake, 6 pistons, 275 pilot sport 4S on all corners and it absolutely sucks on the track compared to the 1SS. Brakes with DOT 4 fluid were cooked after 4 laps on a track that maxes out at 105mph. Melted both my front center caps and lost nearly all brake function yet I have never had a single issue with the 1SS after 6 OTDs. I absolutely hate the LT1 and miss my 1SS every day.
07-27-2022, 11:47 AM | #36 |
Electrical Engineer
FWIW, I did image comparisons between the LT1 and 1SS when I was making my order. Since this thread makes the comparison, i'll share the images.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
07-27-2022, 01:08 PM | #37 | |
Looks like you possibly added the RS package to the LT1? If so, admittedly, I don’t there’s a lot of value in getting the RS package (even though, I have it.. just ended up that way). If it’s straight up LT1 to 1SS, no packages included on either one, it’s more like a $3500 delta. Either way, I think both are good value for the $. |
07-27-2022, 01:15 PM | #38 | |
Electrical Engineer
07-27-2022, 01:16 PM | #39 | |
07-27-2022, 01:18 PM | #40 |
Yea, I don’t disagree with you on the aesthetics. The LT1 does look better with the RS package.
07-27-2022, 01:41 PM | #41 | |
Electrical Engineer
07-27-2022, 02:37 PM | #42 | |
The LT1 Brembo caliper hardware looks a bit different to me.. I know for certain the pads are not the same as the SS. I’m assuming they’re ceramic or a perhaps hybrid to closely match the GM rear brake material, and to reduce cost. |
