07-06-2022, 09:49 AM | #1 |
Drives: 20 ZL1 m6 Join Date: Apr 2022
Nitto nt555rll size
I’m looking to keep my stock front gy tires and change out the back with some nittos. Can the 315/35/20 fit the stock wheel and not rub the fender liners and also will it mess with the stabilitrack being slightly different height? Any info would be appreciated, getting the car back next week and it will be FBO heads and cam so need something better for street driving I have Hoosiers for the track but don’t want to waste them on the street.
07-06-2022, 09:56 AM | #2 |
For a stock ZL1 wheel you will want a 305/30/20. 315/35/20 will be too tall vs the front tires.
2016 NFG 1SS A8
07-06-2022, 09:58 PM | #3 |
07-08-2022, 11:38 AM | #4 |
A few months ago, there wasn't a single 555Rii anywhere. Are they in stock again?
'20 ZL1 1LE A10,
07-09-2022, 08:43 AM | #5 |
07-09-2022, 11:04 AM | #6 | |
Going to start looking for alternatives.
07-09-2022, 11:30 AM | #7 |
Same here. I really wanted to give the NT555R2 a try, but ended up going with the R888R. I’ve been impressed with them so far, although they’re not the quietest tire in the world…
07-12-2022, 10:24 AM | #8 |
I seen them in stock the other day and now they are out of stock again.
It looks like if you order from Summit racing they will ship in 2 weeks.
2016 NFG 1SS A8
07-26-2022, 12:11 PM | #9 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Anyone have experience with the NT555RII?
If they really do offer a tire you can use in the rain with traction of the 555R then I am very interested
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
Tags |
315 35 20, nitto, tire size, tires, wheels and tires |
