01-12-2022, 09:54 AM | #15 | |
Drives: 2021 LT1 A10 RS Join Date: Feb 2021
So its a dynamic of staggered, wider fitments? Here in LA on the freeways at speed it sucks, sketchy. |
01-12-2022, 10:01 AM | #16 |
Drives: Chevrolet Camaro Join Date: Jan 2022
01-12-2022, 10:02 AM | #17 |
That makes me feel a bit better but it still sucks. I’m going to see if they can align it better.
01-12-2022, 10:40 AM | #18 |
I'd think they would have set it up to factory specs since it was a GM dealership unless you told them to set it up for track use. I'd bet its just the wider tires but I would still see if they have a copy of the alignment so you can compare if it ever needs it again or if you start to see abnormal tire wear. I should be saved under you VIN number at the dealership.
01-12-2022, 10:53 AM | #19 |
I don't experience much if any tramlining with either wide wheel+tire combos I've been running recently, the common element between them being PS4S tires. I'm sure the tires themselves play a significant role in this, not just their widths.
01-12-2022, 12:20 PM | #20 |
Drives: 2021 LT1 Join Date: Nov 2021
Are the factory alignment specs the same for all models regardless of what sized wheels/tires are on it? Or do the bigger/wider tires require a different alignment.
01-12-2022, 12:37 PM | #21 |
Yep, I had a set of 1LE-style wheels with the 285-f and 305-r SC3 tires, and they definitely tramlined noticeably more than the 245-f and 275-r PS4S tires that I normally ran.
01-12-2022, 01:16 PM | #22 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Question, I know the LT1 came with a square set up and you changed to a staggered set up. Did you have any issues with traction control or any of the nanny controls on the car by doing that? I would like to change my 2LTRS to a staggered SS set up for track days but am unsure of the drawbacks.
01-12-2022, 01:22 PM | #23 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
So might be worth doing if you have any planned upgrades that require tuning? |
01-12-2022, 01:39 PM | #24 | |
01-12-2022, 02:12 PM | #25 |
j1ss
Drives: '21 2SS 1LE Join Date: Dec 2019
they tramline, its part of having 285s in the front in general, my regular ss tramlined a little bit with the stocks, on 1le size tires it tramlined like the 1le I have now weather I have the street or track alignment
01-12-2022, 02:13 PM | #26 |
j1ss
you just end up appreciating perfect roads more now lol
01-12-2022, 03:06 PM | #27 |
Drives: Camaro 1LE Join Date: May 2018
01-12-2022, 04:22 PM | #28 |
Notice you're from MI, ever go to Gingerman? Did 4 days last year plan on at least 4 or 6 this year.
Tags |
lt1, tires, tramline |
