03-29-2016, 11:20 PM | #1 |
Drives: 2016 Camaro RS Join Date: Jan 2016
Removing scratches with ultimate compound
After I bought my Camaro I went a little overboard with detailing products. Two of the products I purchased were meguiars ultimate compound and the DA power system that is used with a drill. I have never had very good luck with removing scratches until I used these two products together. There were multiple scratches from the half ass detail the dealer gave my car before delivery and a couple of clearcoat blemishes that appeared to be from the factory. Meguiars ultimate compound actually worked in removing all blemishes I had in the paint. Make sure to use a drill capable of at least 2000 rpm's for the DA system and don't worry about burning the paint. This product is very safe to use by amateur detailers like myself. If you haven't used the ultimate compound before I strongly recommend checking it out! It really works!
04-01-2016, 07:02 PM | #2 |
I've had the same issues with my car, I was planning on getting it detailed and apply opti coat. I've been using Meguiars ultimate compound on my daily beater and personally I don't see any results but then again I am not a professional so I don't know all the tricks. If you can post some before and after pictures that will be great.
04-01-2016, 07:13 PM | #3 |
Retired from Car mfrs....
It'll take more than ultimate compound to get deep scratches out of the car. Clearcoat is hard, therefore it does not scratch easily, but when it does, it's hard to clean up. It will take a good orbital, a medium pad, and two polishes from Meguires: 105 and then 205
Here are Meg products ,the left is the most abrasive, the right the least ...
04-07-2016, 07:08 AM | #4 |
I used the DA system that connects to a power drill. The drill was capable of 2000 rpm which is slow but seemed to be enough to get the job done. The scratches were minor. Wish I would have taken pics but ran out of day light. I will get some pics next time. I find surface scratches on my car all the time.
04-26-2016, 11:38 AM | #5 | |
Drives: 16' Camaro 2SS Join Date: Nov 2015
Thanks for posting this. I had been thinking about using the Meguiars ultimate compound as well.l and just came across this. Do you think it will not be effective at all if used by hand? I have a cordless 18v drill, will that be sufficient? Not sure what the rpm rating is on it. But I the swirls aren't that bad, just stand out more on a black car. I'm okay with even trying to get those out by hand, one section at a time. Also, did you use the Meguiars polish or wax after using the compound, to get a better finish it or was wiping off the compound enough?
2016 Camaro 2SS\Jet Black\6MT\NPP\MRC
04-26-2016, 11:43 AM | #6 |
You need to seal after the UC....I really suggest getting a good random orbital and med pad, it makes the work much more uniform that the drill or by hand. Been using UC for years, great stuff.
Follow with a good sealant like blackfire crystal seal or if you want to stay in the meguires family, Meg's NXT 2.0'works well. |
04-26-2016, 05:16 PM | #7 | |
Ah I see. Would the one Meguiars sells be any good? The other one I found was Torqx. I've seen you talk about Griots as the best one... But I'll do more research on that. I got the answer I was looking for, thank you sir!
04-26-2016, 05:25 PM | #8 |
The new meguires polisher is a good one.
04-26-2016, 05:26 PM | #9 |
04-26-2016, 05:27 PM | #10 |
But its 40 bucks more than the griots for no good reason.
04-27-2016, 11:58 AM | #11 |
just checked it out, it is $204 on Amazon vs Griots for $140. That's a pretty big difference. I might go with Griots then.
Would it be a good idea to use a nanoskin sponge first and a wash before using the compound? then sealing with BF as you had said
04-27-2016, 12:13 PM | #12 |
Yeah, just read the docs in my sig...FOR THE EXACT STEPS THAT INSURE SUCCESS....
04-27-2016, 11:45 PM | #13 |
Drives: Overkill Supercharged 2016 CamaroV6 Join Date: Mar 2016
