Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 06-23-2021, 10:33 AM   #1
joeyazzata29
j1ss
Drives: '21 2SS 1LE
2021 1LE mystery flashing CEL
PLEASE DELETE POSTED IN OTHER THREAD
MOVED TO https://www.camaro6.com/forums/showthread.php?t=594047
I will update on this thread^ thanks
Last edited by joeyazzata29; 06-24-2021 at 10:58 AM. Reason: PLEASE DELETE POSTED IN OTHER THREAD
joeyazzata29 is offline   Reply With Quote
Old 06-23-2021, 10:39 AM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Originally Posted by joeyazzata29 View Post
At a track day at Homestead in May I had flashing CEL, service rear axle, service stabiltrac etc... disconnect the battery all is fine and drove home.
Ran a track day w no issues a week later. Yesterday tho, same thing flashing CEL reset battery drove home no problems.
First time dealer had the car for 5 days said they couldn't find anything wrong
really annoying issue has this happened to anyone else?
Code P0300 first time, yesterday the CEL stopped flashing by the time I pulled off the track and no code stuck so idk the code from yesterday.
Only similarity I can think of between the two incidents is less than/around 1/4 tank of fuel. Fuel starvation?
Driving me crazy spending this much on this damn car and having these issues only at the track. Dealer cant replicate it bc you really have to push the car.
Flashing CEL is a misfire, P0300 is a generic misfire code...
2020 Shadow Gray Metallic 2SS - A10, NPP, MRC, Red Calipers, Carbon Flash Wheels, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, SS Logo Armrest, Black Fuel Door, Stainless Sport Pedal Kit, SS Wheel Center Caps, Black Lugs & Locks, GM Body Color Splash Guards, DD Smoked LED Markers, Hero Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Bumper, Hood, Fenders, Mirrors, Rockers; SunTek 35% Tint, CeramicPro coating
Old 06-23-2021, 10:42 AM   #3
ctrlz
Sounds like there are mods the OP has not listed possibly causing the misfire.
And tire sizes pushing the limits of what the stabilitrack system will tolerate.
Old 06-23-2021, 10:44 AM   #4
joeyazzata29
j1ss
Drives: '21 2SS 1LE
No dude this is a totally stock 2021 ss 1le
Old 06-23-2021, 10:45 AM   #5
joeyazzata29
j1ss
Drives: '21 2SS 1LE
Yeah first time it happened it was P0300 misfire and the car was misfiring, dealer found nothing wrong, but how does it go 3k miles 2 months and a full track day with zero issues.... and then happens again on track yesterday
Old 06-23-2021, 11:05 AM   #6
ctrlz
Joey, you are not alone...
Similar problem here:
https://www.corvetteforum.com/forums...misfire-2.html
Old 06-23-2021, 11:13 AM   #7
joeyazzata29
j1ss
Drives: '21 2SS 1LE
Yeah I see so many camaro and corvette threads like this but none just like mine, or none with resolutions. The dealer doesn't seem to want to spend any effort on it. Its so annoying because the car is totally fine until you bring it to the track
Old 06-23-2021, 11:46 AM   #8
Kmeleon
Drives: 2018 NFG 2SS 1LE!
Is your car and Auto or manual? It could be a dfm lifter failure. Going through this with my 2021 Sierra right now
Kmeleon is offline   Reply With Quote
Old 06-23-2021, 11:48 AM   #9
joeyazzata29
j1ss
Drives: '21 2SS 1LE
Auto, is your issue intermittent like this? And only happens under heavy load?
Old 06-23-2021, 01:16 PM   #10
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Flashing CEL is always a misfire. No other conditions can make the CEL flash.
Fuel starvation sounds likely. I personally never let the fuel level go below 1/4 tank at a track; it's just a habit from my RX-8 days.
There was also a guy running a 2.0T at an open lapping day I went to who also had some issues when his fuel level was very low.
As for lifter failure, I doubt it. I once worked on a Toyota Highlander V6 that somehow dropped a valve spring and no one in their right mind could just ignore the vibration. Also, manuals also have the AFM lifters, they are just never activated. Very few failures related to them are reported.
Sent from my MHA-L29 using Tapatalk
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 06-23-2021, 01:20 PM   #11
joeyazzata29
j1ss
Drives: '21 2SS 1LE
Dude thanks for the insight! yeah im thinking this could be it... I had a red SS that had no issues with low fuel, but im gonna try homestead with a heavier fuel load again next month and see what happens. it seems every time this has happened its been on a left turn... would that make sense for sloshing/fuel starvation?
Old 06-23-2021, 01:57 PM   #12
Kmeleon
Yes, gm has a bad batch of dfm lifters in the trucks and cars. So it's possible you're having an issue.
Old 06-23-2021, 02:22 PM   #13
joeyazzata29
j1ss
Drives: '21 2SS 1LE
DFM dynamic fuel management I have AFM active fuel management
This car doesn't seem to stay in v4 mode as often or get as good as milage compared to my 2020 SS or 2017 Silverado. V8 MPG seems good but when it goes to v4 mpg is not impressive. it has trouble staying in v4 at 50mph on a flat road.
I just dont know if its a mechanical issue because it only happens on the race track and a battery reset fixes the issue, no issue on the street.
Old 06-23-2021, 11:55 PM   #14
UnknownJinX
I know in the RX-8, high-G left turns can cause trouble because the fuel tank is saddle-shaped and you can slosh the fuel to the side without the fuel pump(right side) if you pull a high-G left turn.
6th Gen Camaro also has a saddle-shaped fuel tank so it could happen, but I think newer cars all have an auxiliary pump to balance out the fuel level when it's sufficiently low. At least the photo shows something that resembles an auxiliary pump.
Current:
Past:
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
