Old 03-18-2019, 07:18 AM   #1
cmeJATT
cmeJATT's Avatar
Drives: SS-6-SPD
HELP!! ZL1 Door Panels on a 1SS
**SOLVED**
- remove the original switchboard and swap that in to 2SS door panel along with wire harness!
Hey Guys so I last night I swapped my door panels on my 2017 1SS. I swapped them out for the ZL1 door panels. I DID swap the electrical harness so I’m using my ORIGINAL wire harness. The issue I’m having is the mirror switch doesn’t work. I’m being told that switch won’t work due to memory seat option.
So my question is can I switch out the switchboard from my 1SS door panels? Have anyone done this? Is there another solution? Everything else works fine.
cmeJATT is offline   Reply With Quote
Old 03-18-2019, 12:35 PM   #2
srcstc
Can't you use the switch from your door panel?
srcstc is offline   Reply With Quote
Old 03-18-2019, 12:45 PM   #3
cmeJATT
cmeJATT's Avatar
Drives: SS-6-SPD
Does it come out? I haven’t even look at it yet. I did it late night and had work early today.
Old 03-18-2019, 12:48 PM   #4
srcstc
Yeah the switch should pop out. So just swap the switches.
Old 03-18-2019, 12:50 PM   #5
srcstc
It probably just pops off. You might be able to do it without having to remove the door panel.
Old 03-18-2019, 02:23 PM   #6
cmeJATT
cmeJATT's Avatar
Drives: SS-6-SPD
i'll take a look. if you find any video how to remove the switch would be a great help!
Old 03-18-2019, 02:41 PM   #7
srcstc
I don't have any but every door panel I've ever seen the mirror and window switches pop right off. Take a pic of the back of the switch and I'll let you know.
Old 03-18-2019, 03:59 PM   #8
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
I can confirm you have to swap the switch assembly too, it's a bit of a bitch to pop out but will do the trick.
IG: @NC_M1SS1LE
Old 03-18-2019, 04:10 PM   #9
cmeJATT
cmeJATT's Avatar
Drives: SS-6-SPD
once i go hime i'll take a look
i remm you posted last year about the wire harness lol.. i will try to pop out the switch assembly hopefully it comes out easily. any tips so i dont break it lol..
Old 03-18-2019, 07:45 PM   #10
Oramac2016
Oramac2016's Avatar
Drives: 2016 Camaro RS
I second that. I found that out when switching my door panels to ones with spectrum lighting. You have to swap the harness and the switches.
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
Oramac2016 is offline   Reply With Quote
Old 03-18-2019, 08:10 PM   #11
cmeJATT
cmeJATT's Avatar
Drives: SS-6-SPD
Oky so I was able to remove the old switch from my 1SS door panel. Now I gotta find them time to swap it out on the ZL1 panel I’m relieved it was easier than I thought lol.. probably next weekend I’ll swap it!
Old 03-19-2019, 01:18 AM   #12
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
while you have it out. You might want to do something about the round "switch" vibrating the hell out of itself against it's housing. That cheap piece of crap is the noisiest vibrating piece of plastic in the camaro aside from the rear deck plastics.
I'm so close to just dripping rubber cement all around it. Haven't needed to adjust my mirrors in over 2 years.
Old 03-19-2019, 02:28 PM   #13
DarkFangz1100
Drives: 2016 Camaro SS
Swapped door panels on a 1LT to a 2SS panel...everything works 100% with supplied panel electrical
DarkFangz1100 is offline   Reply With Quote
Old 03-19-2019, 02:52 PM   #14
cmeJATT
cmeJATT's Avatar
Drives: SS-6-SPD
really? that's a first .. you're 1LT had memory seats? strange .. didn't work for me or few other people i spoke to on the forum
