05-22-2017, 08:58 PM | #1 |
Battery pull after an O2 sensor change?
Just curious as to the best method for when changing sensors.
Swapping my B2S1 pre-sensor tomorrow due to failure. I'm at +25% LTFT right now. Is it a good idea to pull the battery for a few minutes after the replacement to clear learned values or should I just leave it be and let the trims adjust on their own?
05-23-2017, 07:17 AM | #2 |
Drives: 2011 LS3 Join Date: Jan 2012
You can also do #5 and #20 fuse pull.
Vararam
Stainless Works Headers Vmax TB SLP loudmouth 2 Nightfury Cam Mike Norris CC Tuned by Southwest Speed |
05-23-2017, 11:52 AM | #3 |
Drives: 2018 1SS M6 Join Date: Nov 2014
You can just disconnect the negative terminal before you start. This is typically listed as the first step in many repairs in service manuals, especially for electronic components.
I'm not so sure that this would be relearning thing, as when it comes to O2's the ECU directly responds to the signal it receives. If you don't pull the negative terminal, there still shouldn't be any "relearn" involved, it should operate normally. You will probably still have a CEL which remains for x amount of drive cycles and shuts off when no faults are detected by the ECU. |
05-23-2017, 03:48 PM | #4 |
Alrighty guys, thank you.
Just changed both front sensors and getting ready to fire her up. Fingers crossed!
05-23-2017, 04:43 PM | #5 |
I did a battery pull.
Fired her up and no more stalling or +25% LTFTs. Shes running like a beast now!
