TireRack
Old 08-04-2021, 01:48 PM   #1
Winemedineme69me
Winemedineme69me's Avatar
Drives: Camaro ss Chevy
Results are in ESS tuning G2 blower results!!!
I have the ESS tuning G2 running the 200mm lower and 110mm upper pulley at 12psi on my 2014 Camaro SS LS3. I just put down 780rwhp at 7200rpm on a Dyno jet, I am running 93 pump gas with boostane at 100 octane. It was tuned by Jared at compJLT tuning in Victoria Texas.
Mods are:
Elite Engineering E2X ultra catch can
100 octane pump gas with boostane additive
160 degree tstat
Stock heads, stock intake manifold, stock throttle body
BTR rocker arm trunnion upgrade
Dual valve springs
Texas speed stage 3 blower cam
Melling high pressure oil pump
Ls9 3 bar map sensor
ESS tuning G2 blower kit with 200mm lower pulley and 110mm upper pulley
Ballenger AFR 500v2 wideband
FIC 80lb injectors
ZL1 fuel pump
DSX auxillary fuel pump kit
DNA motoring longtubes, no cats and stock NPP exhaust
AAM 3.91 rear end gear
BMR rear toe rods and trailing arms
Winemedineme69me is offline   Reply With Quote
Old 08-04-2021, 02:06 PM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Nice!
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
larry_g is offline   Reply With Quote
Old 08-05-2021, 06:02 AM   #3
eLeSthree
Drives: 2011 Camaro SS 6sp
I knew these kits would be a hit once the word got out. What does the torque look like?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 08-05-2021, 07:23 AM   #4
Winemedineme69me
Yeah they are great! I don't have the torque because the performance shop that I got it dyno tuned at said that the torque wasn't being read properly by the dynojet. Something to do with their dyno, it read the torque at 6000rpm when it made 690 rwhp and 600rwtq, after that they couldn't get a reading.
Old 08-05-2021, 01:42 PM   #5
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Have them provide SAE numbers too... the graph shows STD.
RealQuick is offline   Reply With Quote
Old 08-05-2021, 01:52 PM   #6
Winemedineme69me
Ok, I just take off 3 or 4 percent for SAE
Old 08-06-2021, 12:54 PM   #7
Silver2014SS
Silver2014SS's Avatar
Drives: 2014 Chevrolet Camaro SS
Sweet! Love my G2 blower as well!
2014 Camaro 2SS - GPI SS2 cam, ESS G2 blower 8 psi 105/160mm, ID1050x, DSX Aux Kit, Kooks Longtubes, hi-flo cats, Borla S-Type catback, BMR trailing arms and OTR bushings, McLeod RXT twin-disc, 3.73 ZL1 diff and ZL1 axles, Innovate Motorsports ECB-1 gauge
733 rwhp/603 rwtq
Silver2014SS is offline   Reply With Quote
Old 08-06-2021, 01:05 PM   #8
Winemedineme69me
Hell yeah, saw what you put down, almost 700rwhp on 8 lbs
Old 08-06-2021, 01:25 PM   #9
SSkat
SSkat's Avatar
That is great power. I want one of these so bad for my L99!
SSkat is offline   Reply With Quote
Old 08-06-2021, 01:47 PM   #10
RealQuick
Thats not exactly how it works... SAE isnt always lower.
If have gone in the heat/humidity of summer where the SAE numbers were adjusted up. I have gone in late Nov where is cold out, and SAE shows lower numbers.
Old 08-06-2021, 03:28 PM   #11
Taylortoons
Taylortoons's Avatar
Drives: 2011 2SS/RS LS3
Congrats! Impressive on pump gas and 80lb injectors. The cycle time must be pretty high.
Gonna need something sticky on them rears.
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
Taylortoons is offline   Reply With Quote
Old 08-07-2021, 02:09 PM   #12
eLeSthree
So was the timing dialed back a bit after the tuning session to compensate for when u arent running 100 octane? Just curious how thats going to work.
1158whp 1017wtq.
630whp 658wtq
Old 08-07-2021, 03:46 PM   #13
Little Walter
Drives: ZL1
Yes STD is normally a little higher than SAE not much, but never the less for the difference you are looking good and making respectable power and have not even ported the heads yet. Awesome!
Little Walter is offline   Reply With Quote
