07-13-2021, 03:23 PM | #57 |
what did i do this my poor car haha and no the cage isnt green its white
12-08-2021, 01:41 AM | #58 | |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
I thought the passenger seat alone weighs 55 pounds, the rear seating 30lbs (upper and lower sections) and there was about 25lbs diff between a racing seat and the stock OEM drivers seat
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
12-08-2021, 05:37 AM | #59 | |
Drives: 1LEs Join Date: May 2009
Personally, coming from years of fully caged drag cars with cage mounted seats, I won't go race seats until I do a full welded-in cage with the front seat(s) mounted properly to the rollcage cross-bar. Heck, I can't even get out the window in the car with helmet on! Not to take the thread down another path, but, if I caged a Camaro, I'd cut down the door and / or put a roof escape hatch. |
12-08-2021, 01:26 PM | #60 | |
I’m thinking of just removing the passenger seat on track days and getting a lightweight lithium battery (in addition to removing the rear seat). Only problem is I don’t know how bad it is to take all that weight off the passenger side of the vehicle. It would only be about a 90 pound difference I would think, so I gues it can’t make too much difference either way
12-09-2021, 04:18 AM | #61 |
Going to race seats is not all about saving weight. Its a safety mod, not to mention holding you in the seat better, better feedback, etc. Depending how you do it and other safety features you add like a roll bar you may or may not see some weight savings. Like I said I did see some net weight saving when I removed the passenger seat and put in just the drivers race seat and used a harness bar. The way I did it using BK mounts etc is not exactly the lightest method either. Now that I have both seats installed and a roll bar it's probably 50 lbs heavier than stock.
12-09-2021, 10:32 AM | #62 |
haha yea i did cage seat harness brackets but only driver side may do passenger in the future and yea weight is probably around same thats why i also added a antigravity battery did you weigh your car yet?
12-09-2021, 10:38 AM | #63 |
Problem with most roll bars I see in these cars is the are not mounted very well with something like a 1/8th" 6x6 steel plate on BOTH sides of the floor pan, either properly welded in or through-bolted. NHRA, SCCA, NASA, etc. rules vary. As mentioned earlier, I personally wouldn't put aftermarket seats in not mounted to the cross-bar of a PROPER roll bar / cage nor would I put in non-containment seats (head side restraints).
Once again, it's all up to each of us personally on what risk we want to take. I know the factory seats have been thoroughly tested in high energy crash events as part of validation. Furthermore, there have been many well documented high speed on track and on street incidents with the seat doing its job. I don't have that warm fuzzy with a lot of aftermarket stuff. I run a Brey Krause harness bar with Scroth Profi II ASM FE 4-point with a HANS - ALONG WITH my stock 3-point seat belt...if the BK bar and / or harness has issues, maybe my stock belt, with pretensioner and the airbags, will help out in an incident. Bolted in (or welded in) roll bars have a lot of mass that does not want to stay in place in a crash, so, I'd want to make sure it is properly mounted. Same with the seats. |
12-09-2021, 10:42 AM | #64 |
yea alot of places in socal wont let you run race seats with a harness with only a harness bar they require a half of full cage bolt in or weld in
nasa is getting more strict with safety also requiring fire systems also next year i read i have a nice little setup and i feel alot safer now and held in tighter so im happy but hoping i never have to use/test out any of my safety gear ever...may look into full suit and shoes next year as i get more serious with time attack series
12-09-2021, 10:53 AM | #65 | |
12-09-2021, 10:55 AM | #66 |
oh yea i understand i just feel its better than nothing and especially better than just stock 1ss seats with stock seat belts it was horrible
at least mine was from garage therapy not studio rsr had a guy from there tell me yea these are mostly for show if you flipped over you would probably die haha wtf who says that
12-09-2021, 02:32 PM | #67 | |
Yes totally agree the largest advantage of a race seat is by far stability. I’ve been debating the race seat so I am more stable while driving, I do have a four point harness which is a lot better than the stock seatbelt obviously, just not sure if I want the aggravation and annoyance of a race seat for summer daily street driving. Unfortunately there are not any race seats I can sit in and try locally in town. But I would be open to one that is comfortable. I’m not sure if any you have a reclined feature or not as I have not done any series looking yet. Also thanks for the clarification, I did not realize you had two racing seats now.
12-09-2021, 02:46 PM | #68 | |
just come down to socal we have a ton of race shops down here including sparco
12-09-2021, 06:34 PM | #69 |
I wish, but Canada and the USA’s two worst all-time leaders won’t let me travel because I’m not fully vaccinated with a vaccine that doesn’t even fully work
12-09-2021, 06:39 PM | #70 | |
well i cant come to canada either if it makes you feel better lol sorry man!
