07-22-2021, 08:43 PM | #99 |
Drives: HBM ZLE Join Date: Aug 2017
Do you think it would be beneficial to come off the supercharger with a straight fitting? anyone else tried this? Thinking it would be good to move it away from the exhaust
07-22-2021, 09:00 PM | #100 |
I wrapped insulation around the bottom of mine for that reason. Moving it would be better.
'20 ZL1 1LE A10,
07-22-2021, 09:12 PM | #101 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Ceramic coating on the headers. The tank doesn’t get very hot. Way less heat under the hood.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
07-22-2021, 09:27 PM | #102 | |
Shadow Gray '19 ZLE M6
I have stock exhaust manifolds and I zip tied the tubing away from both the exhaust manifold and the serpentine belt. I'm confident there won't be any issues.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
07-22-2021, 10:11 PM | #103 |
Thanks, must have glossed over that post. I'll probably go that route. Have ceramic coated csp headers going on right now, installing the resevoir once I get the supercharger back from porting. Also have some heat wrap ready to go for various wires and hoses, just trying to determine the best route for the hose to keep it away from the headers. Thanks again
07-23-2021, 07:06 AM | #104 |
I believe leaving the stock bleeder plastic fitting on the hose is a mistake. There is no reason for it at all and this fitting has been the source of a few failures. You can still bleed the circuit on the top with the little brass fitting and check flow there.
09-11-2021, 06:02 AM | #105 |
Drives: '17 ZL1 M6 Join Date: Apr 2021
How often are you guys topping the reservoir with coolant?
Mine goes down to below the top hose after a few days of filling..
'17 ZL1 M6
8xxwhp Magnuson 2650 |
09-11-2021, 06:37 AM | #106 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
You either still have air in the system or a faulty cap. I went through the same thing. I had both, air and faulty cap.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
09-11-2021, 06:50 AM | #107 | |
Thanks!
'17 ZL1 M6
09-11-2021, 07:41 AM | #108 |
Installed mine in May, the level hasn't changed.
'20 ZL1 1LE A10,
09-11-2021, 08:01 AM | #109 |
Looks like mine wasn't bled enough after my cam install.
Removed cap, ICP & Fan on using my gauge and let her idle for 15 minutes. Added coolant every 5 minutes until it stayed level. She took around half a gallon more coolant Will observe closely
'17 ZL1 M6
09-11-2021, 09:08 AM | #110 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
09-12-2021, 12:20 AM | #111 | |
Post cam - Went low enough for me to fill Most likely was not bled enough
'17 ZL1 M6
09-12-2021, 02:36 AM | #112 |
