06-05-2019, 03:19 PM | #43 | |
Drives: ZL1 1LE Join Date: Oct 2016
06-05-2019, 07:18 PM | #44 |
Drives: 2018 Nightfall Gray Metalic ZL1 A10 Join Date: Feb 2018
Hi,
Just noticed my post is missing some additional info. This is a follow up post from earlier in the thread (#29 and 31) regarding some pads someone found on ebay for $150 the set (front/rear). The part number was an older discontinued part number that "should" have been compatible with the current one. I took a chance but, as you also noticed, they are clearly not the same. I think they would still work, just not as well.....and certainly not as well for a track situation. |
07-04-2019, 10:17 AM | #45 |
Drives: '19 ZL1 1LE Join Date: Feb 2019
Has there been any conclusion on the pads for the ZLE?
It looks like it is documented that the pad compounds for the ZLE are different. If so, what is the correct part number for the OEM pads? |
07-04-2019, 11:00 AM | #46 |
Drives: 1LEs Join Date: May 2009
All the flavors of 1LE’s, SS, and all ZL1 use Ferodo HP1000 compound. The Delco #s: 171-1192 front and 171-0882 rear for J6H brakes (ZL1). You can see it printed and / or stamped on back sides of the pads.
07-16-2019, 02:32 PM | #47 |
Drives: gas powered Join Date: Jan 2019
10-11-2020, 09:40 PM | #48 |
Drives: 2017 ZL1 M6 Join Date: Oct 2020
This item number doesn't seem to pop up any longer. Can you PM me a link to the seller's store?
10-12-2020, 03:12 PM | #49 | |
Drives: 2020 Camaro ZL1 1LE Join Date: Mar 2020
The new brake pad law WAC 173-901-050 takes effect 01/01/2021. This will effect the allocation of Brembo Brake Equipped vehicles in Washington because the pads contain more than 5% copper. This means if you are thinking of a new Brembo Brake Equipped Car you should place an order with a dealer soon. Vehicle allocation will likely be disrupted in Washington and California at least initially. https://apps.leg.wa.gov/WAC/default....te=173-901-050 |
10-12-2020, 04:41 PM | #50 |
That's absurd
10-13-2020, 02:28 PM | #51 |
10-15-2020, 06:05 PM | #52 |
Drives: 2017 Camaro ZL1, 6M Join Date: Dec 2019
Here's what I just received from gmpartsonline.net when I ordered OEM ZL1 front pads ($307 delivered vs $410 at the dealer down the street). Took over 6 weeks to get, but that's the same lead time my local dealer quoted.
Note, although the shipment was well protected, I did notice a few chips on the friction material on the corners. |
07-24-2021, 03:55 AM | #53 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
Maybe this will also help in terms of price:
Front brake pads, AC Delco part#: 171-1192 https://www.ebay.co.uk/itm/Disc-Brak...-127632-2357-0
Mosaic black 2018 Camaro 2SS A8 (sold) |
07-24-2021, 07:42 AM | #54 | |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I track my SS with standard ZL1 brakes every chance i get and have been pleased with the ZL1 pads. When it comes time to replace them, I will go with the ZLE pads. I wonder if the difference between std & ZLE pads is even noticeable on the track?
Baby Blue
07-24-2021, 11:24 AM | #55 | |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
07-24-2021, 11:53 AM | #56 | |
Baby Blue
