04-19-2021, 08:19 AM | #29 | |
'20 ZL1 1LE A10,
04-19-2021, 09:43 AM | #30 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
Interesting, I pulled 670whp with just the edelbrock 2650 and a tune
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
04-19-2021, 12:31 PM | #31 |
Petro-sexual
Moving from a standard RF to their BG required about 25% more fueling for another car I know about (no other mods'). Just sayin'...
04-19-2021, 12:38 PM | #32 |
Dyno Show Queen LOL
According to Mikey on his corvette it makes 740 rwhp stock TB and no headers.. so wtf?
06-22-2021, 02:17 PM | #33 |
Drives: 2018 Cadillac CTS-V Join Date: Jul 2012
Any updates OP? I’m pretty with the exact same parts in mine so it’s a good chance I will get the same outcome. The only changes I did was go ahead and order the 103mm NW TB, 103mm snout and the JMS Fuel Max. So, I am hoping that the custom tune will get better numbers than your highest.
Still stock headers and cats. |
06-22-2021, 05:36 PM | #34 |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
Don't need the big gulp and yes, the standard rotofab will fit on a 103mm tb.
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
06-22-2021, 06:11 PM | #35 |
This is another really good reason to avoid dyno numbers. It's much more important to focus on getting the car to run like you want it to, like it should run
'20 ZL1 1LE A10,
06-22-2021, 06:55 PM | #36 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Didn't see it mentioned, but how were your dyno numbers displayed? The shop I used displayed my numbers as uncorrected. SAE correction bumped them appx 40hp in my case. I see the compare dyno numbers were SAE. Just verify if yours were.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
06-22-2021, 07:07 PM | #37 | |
Drives: 2019 ZL1 Join Date: Mar 2019
You know you can get a stockish idle cam that has no lope and just a bigger fuel lobe right ? You also need headers and a bigger tb. This is your missing hp.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
06-22-2021, 07:40 PM | #38 | |
Time to get creative and figure out how to get to hellcat/gt500 power and still keep the equipment on… or easily swappable |
06-22-2021, 07:46 PM | #39 | |
Dyno Show Queen LOL
Lpe cam has the 38% and 42% specifically for there pump with no chop at all.
06-22-2021, 07:49 PM | #40 | |
Dyno Show Queen LOL
So ported heads, ported blower, smooth idle cam and best California will let you do!
06-22-2021, 08:04 PM | #41 |
Drives: 2017 Camaro ZL1 A10 Join Date: Jan 2017
I don't know much about cams so it's good to know you can add fuel and still have a stock-like idle. I'll add it back to my list of things to consider (along with headers)
I'm literally in my garage right now adding:
I'm booked to go back to the dyno this Friday so keeping my fingers crossed I'll see some better gains + get rid of the low side fuel drop at WOT (was down to ~50PSI). From there I can see I need to do more to hit my goal of 800 crank.
2017 ZL1 Black, A10
Build: Magnuson 2650R, 103NW Throttle Body, Rotofab Big Gulp, Kooks 2" headers, Catless, AWE Touring exhaust, JRE Smooth Idle Cam, Katech Oil Pump, Elite Catch Can, JMS Fuel Booster |
06-22-2021, 08:47 PM | #42 | |
I’m guessing that the big issue with power will be effective octane and ability to add timing. |
