04-13-2018, 07:25 AM | #1 |
Drives: Overkill Supercharged 2016 CamaroV6 Join Date: Mar 2016
High Pressure Fuel Pump Information Thread
Currently collecting data on the Fuel pumps to try to find a compatible upgrade for us. If anyone has any information please feel free to provide it.
2.0T - Ac Delco - HPM1015 Inlet Header Length 4.500 MM Connection Type Female Mounting Hardware Included Yes Gasket or Seal Included Yes Housing Material Stainless Steel Maximum Flow Rating 37 Inlet Diameter 0.177 Inlet Diameter 4.500 MM Inlet Type Female Threaded Outlet Type Female Threaded Outlet Quantity 1 Outlet Diameter 0.177 Outlet Diameter 4.500 MM Mount Hole Quantity 2 By design Our pump is very similar specs wise I have no clue. 3.6L - HPM1027 I cannot find technical data on our pump but.. This Ac delco pump is used in about 50 different applications and is direct replacement for All 16 17 3.6l LGX applications Buick Cadillac and Chevrolet Our pump is used in the CT6 3.0tt LGW Application as well. 6.2L - ACDELCO HPM1035 Mounting Hardware Included Yes Gasket or Seal Included Yes Housing Material Stainless Steel Inlet Diameter 0.374 Inlet Diameter 9.5 mm Inlet Type Tube Outlet Type Threaded Outlet Quantity 1 Outlet Diameter 0.551 Outlet Diameter 14 MM Mount Hole Quantity 2 6.2l Zl1 - ACDELCO HPM1036 By Design the SS and LT4 Pumps are much different then the 2.0t and the 3.6l I do not believe we could swap out for either of these. Cadillac ATS-V 2 parts # found ACDELCO HPM1013 and ACDELCO HPM1030 Data for the HPM 1013 Inlet Header Length 6.400 MM Connection Type Female Mounting Hardware Included Yes Gasket or Seal Included Yes Housing Material Stainless Steel Maximum Flow Rating 41 Inlet Diameter 0.251 Inlet Diameter 6.400 MM Inlet Type Male Quick Connect Outlet Type Female Threaded Outlet Quantity 1 Outlet Diameter 0.251 Outlet Diameter 6.400 MM Mount Hole Quantity 2 By Design these are very similar to the 2.0t and the 3.6l pumps. And there is a possibility the ATS-V could be a direct Swap need to find more technical data on our fuel pump first. As with all Ac delco parts there seems to be alot of confusion with alternate part numbers and data I am starting this thread to record and update all the information I find.
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/ Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA Supercharged with Overkill Superchargers http://www.v6superchargers.com |
04-13-2018, 11:09 AM | #2 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Good info, thanks for posting!
I guess let me add to this as its fuel related, I measured the stock stroke on the 2.0 HPFP at .300"... I measured the lift on the fuel pump lobe on the camshaft that drives the pump at .160"... This leaves about .14" of available stroke left in the pump... Now ZZP currently sells their "upgraded" 2.0 camshafts with a total lobe lift of .200" stroke. (still leaving .100" of stroke avaiable")... NOW you obviously don't want to attempt to take up that whole .300" of stroke available in the pump as it could be put in a coil bind situation and you'll probably break something, BUT a guy could probably take it up to say .23-.25" of usable stroke in theory. You'd have to do some research on the LGX pump, and fuel pump lobe to get some numbers, but theoretically if numbers allow (similar to mine above, you know), could have someone regrind the fuel pump lobe of the cam shaft, and remove material out of the base circle to get that additional pump stroke out of it. The fuel pump lobe on the LGX looks to be a 3 lobe, design? where as the LTG is a 4 lobe (its basically a square on the camshaft)... It took me a while but I finally found a place that can theoretically regrind the LTG cams for me, but more importantly, they can do the fuel pump lobe, removing material from the lowest point before the next ramp, to increase the fuel pump stroke. I should have my cams back within the next 1-2 weeks... If it works out for me, it may be doable on the 3 lobe LGX cam to gain you some more headroom in the fuel department. Last edited by Jason@JacFab; 04-13-2018 at 11:43 AM. |
04-13-2018, 01:02 PM | #3 | |
The whole grinding the cam lobe etc.. is def not in the realm of my knowledge. I would probably go ahead and purchase an OEM one to have sent out. Please forgive my ignorance here so the idea is to get the pump to open more ? in my head it worked the other way around push it in further giving it more pump effect.. But I guess the idea works both ways.. and the whole grinding makes more sense. Also was spying on your LTG Site gonna try out some of your TCM tricks.
04-13-2018, 02:27 PM | #4 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Back from when GretchenGotGrowl's car was a thing, he used the LF3 or LF4 HPFP in his LFX and it supplied him with enough fuel, I think, for his 600+whp current target. It needed like a Ferrari lash cap (you might be able to pm Rhino GPI I think it was) but if you are so lucky as to be able to use it, I would definitely say try that route. Not super hopeful though.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
04-13-2018, 03:16 PM | #5 | |
The pump doesn't really "open" per say, think of it like a small engine, or compressor... It has a piston inside of it, and the fuel pump lobe makes it go up and down... So like a STROKER motor, if you increase the stroke, it will increase the output. OR like some of the other GDI people out there are doing, if you can disassemble , bore it out and put a bigger piston in it, again more output (ie BIG BORE) motor. I know the LTG HPFP can't be disassembled, its a welded unit. Not sure about the LGX? I know that an LFX pump can be disassembled. I also think that LT1 pump comes apart, as Lingenfelter offers one with a bigger piston thats like $1500, call it a big bore, its a direct replacement for an LT1/4, they claim it flows 30% more fuel than a stock LT1 pump, and 10% more than a stock LT4 pump. |
04-13-2018, 11:42 PM | #6 | |
04-16-2018, 10:37 AM | #7 | |
I’m guessing it would have to be made, OR possible a larger one from a different hpfp could be used? But then you’d be buying 2 (expensive?) pumps just to make one, and I’m assuming you’d still have to bore out the lgx pump somehow to work with the larger piston. Maybe I’ll look for a cheap used LT1 hpfp on eBay and see what’s involved in doing such a thing, as we know it comes apart. I’ll keep you posted on the cam thing. Sent from my iPhone using Tapatalk |
07-13-2018, 12:39 PM | #8 |
I just bought an Lt1 hpfp off of ebay. Not for i4 or v6 purposes per se, but I will be taking it apart, attempting to replicate something similar to the LPE big bore pump, and sending it to a guy with a ZL1.
Will be a good learning experience for future i4 / v6 stuff. |
08-09-2018, 06:28 PM | #9 |
It would seem that many companies are modifying the Lt1 and LT4 fuel pump to fit smaller engines after doing some research. I received my LT1 pump and have already started modifying it, of course I'll do the LTG first since I've got a bunch of them laying around here, but I can also do one for the LFX as I still have a spare LFX engine. I'd need an LGX fuel pump to take measurements off of to make one fit that.
