Old 12-22-2017, 09:18 AM   #1
luke2220
luke2220's Avatar
Drives: 16 black on black camaro rs
Pull fuse on v6 npp exhaust?
Hi Everyone,
Has anyone pulled the fuse on the npp dual mode exhaust for a v6? does it make a difference? does it get annoyingly drony when driving long distance? does it void the warranty? can you put it back in if you want to?
thanks in advance!
**EDIT**
I tested out the fuse pull and am happy with the results definitely deeper idle and more crackling/ backfires when revving and driving. And the valves don't close when your driving on the highway/ backroads so whenever you accelerated the exhaust is fully open.
I made a video to show the differences if anyone is interested in doing it! I have an RS Camaro I would assume that with the SS or ZL1 the fuse pull will make an even more difference.
2016 RS, NPP dual mode exhaust, black 20 inch SS rims, black bowties
NPP Fuse Pull Exhaust Upgrade!
https://www.youtube.com/watch?v=-rdkmmIe1gY
DIY Inexpensive undercarriage washer!
https://youtu.be/a2iMtVYMw9I
Make tires look new!
https://www.youtube.com/watch?v=aGQyzzpEH8o
Youtube Channel:
https://www.youtube.com/channel/UCDo...2UkgZW05nJPSHA
Second Youtube Channel (Money topic):
https://www.youtube.com/channel/UCM5...4LWhcVaTjmPnkg
luke2220 is offline   Reply With Quote
Old 12-22-2017, 09:37 AM   #2
jchappies
jchappies's Avatar
Drives: 2018 Camaro 1LT RS
Yes I pulled mine, no drone at higher speeds. It's a fuse...you can put it back in if you need it.
All it does is keeps the exhaust valve open. It's great for a free mod.
2018 RS, A8, NPP, NFG
2011 Jeep Wrangler RIPP Supercharger
Gulf war Vet. USAF
jchappies is offline   Reply With Quote
Old 12-22-2017, 11:09 AM   #3
luke2220
luke2220's Avatar
awesome thanks so much! ill have to try it out!
Youtube Channel:
Old 12-22-2017, 12:59 PM   #4
tej
Drives: 2018 2ss Borla ATAK Cat Back
I pulled my fuse in February and its a lot better. If you want to step further to add more sound, keep the stock muffler (NPP) and delete resonator and put x-pipe, the difference is day and night and you don't have to spend $1000 + on Borla or another company.
tej is offline   Reply With Quote
Old 12-22-2017, 01:38 PM   #5
302Blue
302Blue's Avatar
Drives: 2017 Camaro V6 1LE
Did you get a CEL?
302Blue is offline   Reply With Quote
Old 12-22-2017, 02:15 PM   #6
ChangerOfWays
ChangerOfWays's Avatar
Drives: 2017 2LT RS
I've had the fuse pulled for about a month and so far, no CEL.
I also read issues about '17 models reclosing the valves even with the fuse pulled, but I haven't had that happen yet.
Be ready for the secondary tips to get alot dirtier, more quickly
ChangerOfWays is offline   Reply With Quote
Old 12-22-2017, 02:32 PM   #7
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Long term, i’ll bet you put the fuse back in.....
Old 12-22-2017, 05:13 PM   #8
Kairles
Kairles's Avatar
Drives: 2015 Camaro 1SS
Don't the valves stay open when in "sport" mode?
Kairles is offline   Reply With Quote
Old 12-26-2017, 05:39 PM   #9
Buzzberd6
Buzzberd6's Avatar
Drives: 2LT/1LE, HPCRX, F250(tow vehicle)
I'll take that bet!
I removed mine over a month ago. While there is definitely a difference at both startup and steady state cruising, it is in no way offensive.
If it was, 'she' would have noticed it and said something. Not a peep from her.
I thought I'd be putting it back in, as I did several months ago when I took it out for a few days. I don't even notice it now.
Pretty sure it's staying out.
2017 2LS 1LE
'I feel that life is measured in achievement, not in years alone'
Bruce McLaren
Buzzberd6 is offline   Reply With Quote
Old 12-26-2017, 06:09 PM   #10
Dcsimpkins
Dcsimpkins's Avatar
Drives: 2016 RS Summit White Black Stripe
I've had mine out for 20 months now and probably will never put fuse back in lol.
Dcsimpkins is offline   Reply With Quote
Old 01-03-2018, 09:29 AM   #11
luke2220
luke2220's Avatar
Originally Posted by Buzzberd6 View Post
I'll take that bet!
great thanks for the info! ill def have to give it a try once its warmer out and i take the camaro out again
did you notice any check engine lights going on?
Youtube Channel:
Old 01-03-2018, 09:30 AM   #12
luke2220
luke2220's Avatar
awesome! thanks! have you had any issues with check engine?
Youtube Channel:
Old 01-03-2018, 09:32 AM   #13
luke2220
luke2220's Avatar
great!! and yeah I've heard things about the 17 models as well! luckily maybe the 16 models won't have that issue! and that's okay I give my exhaust tips and nice clean every wash
Youtube Channel:
Old 01-03-2018, 12:15 PM   #14
cthompson07
Drives: 2016 hyper blue 2ss
Be warned, I tried pulling the NPP fuse one day driving around town, and noticed the blind spot monitoring quit working while the fuse was pulled. Didn't light up when starting the car and didn't work while driving. Saw a couple other posts with the same issue.
cthompson07 is offline   Reply With Quote
