Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 06-16-2020, 04:59 PM   #1
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
Hard Start/Extended Crank and Service Stabilitrak Message
I've been having this issue for a long time now. The car usually starts fine if it's cold, but the issue starts when I try to start it less than a few hours after a drive. I always get a really slow crank with a start after 4-5 rotations, or sometimes closer to 10. After it starts, I get the Service Stabilitrak Message on the DIC, the 3 traction control/stabilitrak lights illuminate, and the tach doesn't work. I also get the crank position sensor code, and sometimes a misfire light. I've already replaced the crank position sensor, since it's cheap and easy, but the last time I had it looked at they said the alternator tested bad. I'm thinking I'll try that next, but I wanted to ask first before throwing parts at it. The voltage gauge in my 4 pack gauges shows that it's charging, but it makes sense in my head. Battery is expended from a crank cycle, then next start there isn't enough voltage to start the engine and feed all of the sensors, so the crank sensor gets "bypassed". Am I on the right track here? Super annoying and inconvenient... May try adding another ground cable.
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 06-16-2020, 06:13 PM   #2
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Yes. I would check battery voltage first (charging and not), then grounds, then alternator. If all that checks out, you will need some parts.
JB'sZL1 is offline   Reply With Quote
Old 06-16-2020, 09:47 PM   #3
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Is it the original battery? I’ll bet it's come to the end of its useful days. Just a guess, of course.
0stones0 is offline   Reply With Quote
Old 06-16-2020, 10:44 PM   #4
caper
Drives: 2010 IOM 2ss/RS
this is a COMMON problem...chevy where are you on this??? theres a few threads on here. one in the v8 engine section right now. i have done everything from replacing the CPS sensor, starter, battery, add a ground, bypass the jump start post etc etc...nothing. some guys have had some luck with those. the other thread i mentioned says to look at the ground in the trunk and clean it. my car is in nthe shop for another issue but when i get it back ill try that. ive been chasing this for a long time. car only starts if it sits a long time....so there i am stuck at a gas station or some shit for 40min.
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
caper is offline   Reply With Quote
Old 06-17-2020, 07:15 AM   #5
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
The most obvious potential problem is an old battery.
If you already changed that, people have found poor grounding cable connections or high cable resistance.
Either way, the Service Stabilitrak message is the classic indicator of low battery voltage.
Old 06-17-2020, 02:36 PM   #6
rebelyell22
It's to the point I've considered a new car.
Old 06-17-2020, 03:29 PM   #7
608RS
608RS's Avatar
Drives: 2015 2ss
just curious what is your battery voltage reading prior to starting in this scenario?
2015 Camaro 2ss, NicKey Performance built/tuned
608RS is offline   Reply With Quote
Old 07-04-2020, 11:39 AM   #8
fleebag
fleebag's Avatar
Drives: Moneypit
I had that issue too for a while and drove me nuts..
My fix was playing with the tune, start up timing and air flow I think. Maybe try that?
fleebag is offline   Reply With Quote
