dave@hennessey
Old 02-17-2017, 06:19 PM   #1
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
How I added a LFX LLT Electric Vacuum Brake Booster Pump
I have the details on my build thread, but I'll post the relevant parts here:
Pump and Hose (with part numbers):
http://www.camaro5.com/forums/showpo...postcount=1089
Male connector:
http://www.camaro5.com/forums/showpo...postcount=1091
External Fuse Box with relay:
http://www.camaro5.com/forums/showpo...postcount=1094
6061 Aluminum for custom bracket (thanks to alice in the v6 section!):
http://www.camaro5.com/forums/showpo...postcount=1102
http://www.camaro5.com/forums/showpo...postcount=1103
http://www.camaro5.com/forums/showpo...postcount=1104
Where to mount pump:
http://www.camaro5.com/forums/showpo...postcount=1106
http://www.camaro5.com/forums/showpo...postcount=1113
Hose setup:
http://www.camaro5.com/forums/showpo...postcount=1114
http://www.camaro5.com/forums/showpo...postcount=1115
Harness I made with the programmed micro-controller:
http://www.camaro5.com/forums/showpo...postcount=1118
http://www.camaro5.com/forums/showpo...postcount=1119
Vacuum Pump test with Video!
http://www.camaro5.com/forums/showpo...postcount=1120
Hose Routing:
http://www.camaro5.com/forums/showpo...postcount=1121
Why:
https://www.camaro5.com/forums/showp...postcount=1124
Startup:
https://www.camaro5.com/forums/showp...postcount=1125
Works great! I have a VVT SS1 cam and sure, will get vacuum eventually, but that cold startup, this solves the problem.
All GM parts (hose and pump) and these are from an LLT/LFX Gen 5 Camaro!
Give credit where credit is due:
http://www.camaro5.com/forums/showthread.php?t=382917
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 03-10-2019, 10:40 AM   #2
Roader
Drives: Camaro
Thanks don. Going to look over your links and research this. Been looking for something similar.
Roader is offline   Reply With Quote
