Old 06-17-2021, 05:54 PM   #15
JairCholico
Drives: Chevy camaro
Really? Which freeway did you spin out on without causing a pile-up?....How did you every get it off the freeway?
You also never answered anyone in your other thread about the same battery and stalling issue...
https://www.camaro6.com/forums/showthread.php?t=581130
Because I found out that the problem was the heat soaker , I didn’t know about the starter issue, and I didn’t crash cause it was at 3 am , that’s why I’m thankful there was no cars on the road
JairCholico is offline   Reply With Quote
Old 06-17-2021, 05:56 PM   #16
JairCholico
Originally Posted by AZIROC View Post
Just to "play nice", my best advise is take it to a shop. It sounds like you have multiple issues going on that COULD range from rear end, trans, and electrical.
Do you have any engine codes?
My buddy is going to go through it tomorrow with the computer, and see if anything pops out , I’m thinking it’s electrical also, cause the tow truck driver tried charging the battery and nothing happened
Old 06-17-2021, 05:57 PM   #17
JairCholico
Originally Posted by zaimer View Post
Troll or not, call a tow and pay someone to deal with your issues. The purpose of this forum isn't to drop in once a year, and provide no follow- up or even a response. That is unethical IMO and I wouldn't offer you a solution if I had one.
I only really come to this forum when I had problems, the last time I posted is because I didn’t know about the stater problems when the car gets a lot of heat
Old 06-17-2021, 06:01 PM   #18
JairCholico
Originally Posted by ctrlz View Post
yeah, this car would be towed/impounded if not removed in a day or so. Especially if it "spun" onto the side of the road.
After the car was done spinning I was able to use the rest of my momentum, to make it on the side of the road , it happened on the left side of the freeway and I ended up on the right side , so it wasn’t that far I had to get the car to move
Old 06-17-2021, 06:52 PM   #19
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
To the Op, get your Camaro checked out to avert a possible disaster for you and other drivers.��
