06-08-2021, 02:49 PM | #1 |
Drives: 17 SS 1LE Join Date: Feb 2021
Trying out the dragy 60-130
Hey all just wondering what your guys times are, this thing is pretty fun to mess with. Going to get some 1/4mi runs in this weekend but I figured id give it a hit on the way to work this morning.
17 SS 1LE 715whp 638tq |
06-08-2021, 05:02 PM | #2 |
Drives: 2016 Camaro SS Join Date: Jul 2020
12319ft DA is brutal
06-08-2021, 06:48 PM | #3 |
06-10-2021, 07:16 AM | #4 |
Drives: Turbo 6.2 Join Date: Feb 2019
My buddy wanted to see what mine did so we did a pull with his draggy. Something like a 5.3 second 60-130. He said it was pretty good for having both of us in the car with the kids crap in the back. Starting at ~58mph and flooring it probably didn't help the time. If I ever do it again, i'll be WOT before 60mph =].
I might have a pic of it. ill take a look
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
06-10-2021, 10:38 AM | #5 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
Yeah, something is wrong... was this on a street tire with 700+ HP?
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
06-10-2021, 10:47 AM | #6 |
Drives: 2016 Camaro SS Join Date: Sep 2018
I was going to say that is really slow for 700 then I saw that DA.
06-11-2021, 03:17 PM | #7 | |
Im on micky t et streets so there isnt much wheel spin. The day I dynoed the DA was 4900ish but its summer time now and DA gets awful. I did a 1/4 mile run too but with cold tires and cold ground it didnt do so well lol. Not to mention the elevation. I think at SAC drag strip i should be mid 10s Last edited by THASTIG; 06-11-2021 at 03:27 PM. |
06-15-2021, 09:50 AM | #8 |
I plugged your dragy 1/4mi time in the drag times calculator. In 0 DA that run would be 11.3 @ 127 with the same 60ft. Get the 60ft down in the 1.7 range and it would run high 10's @ 130 which isn't bad for a full weight 1LE. Cars seem to run much slower at the Nevada drag strip then most other places in the country.
2016 NFG 1SS A8
06-15-2021, 10:12 AM | #9 | |
@Blackmamba_1LE
I ran 1.79 60', 10.6 @ 135 full weight 1LE (stock front 20's) I made 680 on the dyno. Dont remember DA but its south FL... its always bad. We may have an inflated dyno situation here.
06-15-2021, 03:46 PM | #10 |
Pray toons ftw!
2016 NFG 1SS A8
06-15-2021, 09:11 PM | #11 |
@Blackmamba_1LE
You have basically the same numbers as I, what power you made for that 10.5?
06-16-2021, 09:25 AM | #12 |
I never dyno'd the new combo. The car originally made 596whp STD in 5th gear with drag radials. That was before the Rotofab big gulp and 3.375 pulley along with some tuning changes.
2016 NFG 1SS A8
06-18-2021, 12:01 AM | #13 | |
06-20-2021, 03:38 PM | #14 |
Drives: 2018 2ss 1le Join Date: Jan 2018
thats also a dyno jet wich i believe gives higher numbers probably closer to 675 on a mustang dyno
thats what ive been told anyway... im 600 wheel and my 60 130 is like 8 and change and thats not using a draggy i use the pdr and time it so may not be that accurate
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned |
