Old 05-30-2019, 09:22 AM   #1
rlarsen462
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound)
Seem about right for ~6500-7000 DA?
So the ZLE is the first high HP RWD car I've ever taken to a drag strip, so my launching was pretty much horrible all night. Trying to figure out if these numbers at least seem like the car is making the correct HP.
Bandimere Speedway is at 5800ft above sea level so the DA's this time of year are usually 6500-7000, I don't know the exact figure for yesterday afternoon though.
Only mods are a Rotofab wet filter and a Weapon-X ported TB. Also ADM intercooler reservoir but doubt that makes any difference.
I did not pull the battery cable before going to the track.
Before my last run I finally dropped my rear tires all the way down to about 23-24psi, I didn't feel like putting the stock wheels/tires back on so I ran my Michelin PS4S's too.
Here's my best run:
60' - 2.196 (believe it or not this was the best of the night...)
330 - 5.554
1/8 - 8.270
1/8 MPH - 90.29
1000 - 10.582
ET - 12.529
MPH - 116.48
So obviously I need to launch better. I was using the no lift shift and this run was clean on shifts. Still fought some wheelspin then bog using the launch control at 3700RPM & 10% slip target.
I know the aero also makes the ZLE slower in the 1/4 since it's not a drag car, but does this seem about in line with a car making correct near factory power levels?
Thanks for any advice on driving the damn thing too, I would like to take it again before I take it to the road course just because the strip is literally like 2 minutes from my house.
EDIT: Forgot to mention, I ran in Track Mode with PTM Race engaged (double press traction control button and scroll down to Race)...should I have run with the long press EVERYTHING completely off?
rlarsen462 is offline   Reply With Quote
Old 05-30-2019, 09:54 AM   #2
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
That mph seems low for a ZLE I'm.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 05-30-2019, 10:23 AM   #3
rlarsen462
Sell Low, Buy High
Thought so too, so I looked at this calculator:
https://www.ajdesigner.com/fl_horsep...trap_speed.php
Using a weight of 3883lbs, I got ~480RWHP calculated.
From what I could find, these cars dyno stock in the 500-580RWHP range.
If we assume the high end 580RWHP then 480RWHP would be 17.2% reduction, at 7000ft DA puts it about 2.5% HP loss per 1000ft DA.
Does this still seem way off?
Note that I did not turn the nannies completely off, I was in Track/PTM Race. I also didn't reset the battery.
Old 05-31-2019, 03:59 AM   #4
wnta1ss
Drives: 2017 Camaro 1SS
I think your 3883 weight is just the car? You need to use the actual race weight with driver in your calcs.
5800' ASL is going to slow it down, even having the supercharger.
Old 05-31-2019, 04:03 PM   #5
rlarsen462
Sell Low, Buy High
Oh yeah good point. I had nearly a full tank of gas and my fat ass in the car so it was probably over 4100-4200 lbs.
Re-ran it at 4200lbs and got 511HP which seems a little more reasonable.
