Old 01-26-2020, 07:17 AM   #1
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Looking for wider tires out back, wheel suggestions?
Car is a 2017 ZL1 with 200+ whp over stock and still adding more as we speak. Looking to fit a wider tire out back and possibly move up the width in the front.
After 3 years and many people trying different combinations is there any recommendations you guys can make, looking for people to respond that have a combination wheel/tire actually installed. I don't mind minor tweaks to the front struts or wiring harness moves (seen so far these are pretty common tweaks). Wouldn't mind if they were easier to clean too
Running PS4S stock size on stock wheels right now. They can hold 2 gear kinda but don't get enough traction in first as you'd imagine. Car is normally street driven but occasionally it attends some HPDEs.
Thanks.
Old 01-26-2020, 09:53 AM   #2
Markoz28
Drives: 18 ZL1 nightfall grey A10
I went 295/30/20 up front and 325/30/20 out back. Wheels are 20x10 up front with stock OS. For the back I went 20x11.5 with +41 OS. Wire harness on drivers rear side has to be moved in board with zip ties X2 and fender liner needed to be massaged in a bit using $10 heating gun and roller. Everything fits great! But if I oils do it again I would have gone with +42 or 43 for the rear OS just to move the tire a bit more in. Still no regrets tho.
Markoz28 is offline   Reply With Quote
Old 01-26-2020, 10:03 AM   #3
SlikZL1
Drives: 2019 Camaro ZL1
Are you looking to stay within a 19”-20” wheels?
If not, I think the best choice is a 17x10 for the rear with a 305/45 street r. Just helped a buddy mount/balance and align his new signature wheels. He has 1le specs all around. His car makes 700whp and has the Michelin cup 2’s(305 Front,325 Rear). Traction is much better but he still can’t get it to hook. No wiring harness re route needed for his but he did knock the front struts down with a grinder due to the added negative camber and added wheel width.
For my 17x10, I relocated/moved the harness in the drivers fender. All I did was undo/remove the factory zip ties and moved the harness up towards the fender and re zip tied it.
Another thing you could look into is a R888 or a Street R in a 305/35 20 size for the factory wheels, but the tire is like 29” which seems to freak the cars out by offsetting the front and rear so much. Also, looks kinda goofy imo.
These cars do everything great! Seems like the best bet for you (and me too) is to get a drag pack for playing and a track set for the turns.
SlikZL1 is offline   Reply With Quote
Old 01-26-2020, 12:27 PM   #4
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Looking for 19-20" range, not interested in R888.
Old 01-26-2020, 09:35 PM   #5
Markoz28
Well for 20” wheels you limited to the sport cup 2 or the r888r. May just want to go with 19s
Old 01-27-2020, 06:53 AM   #6
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
If you can run the 19x12 1le rim you can run the toyo R888R 345 30 19 maybe even the 355s
I'm running the the 345s
Old 01-27-2020, 07:52 AM   #7
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Are you running the actual 1LE wheel or an equivalent 19x12+41?
Old 01-27-2020, 08:01 AM   #8
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Im running 19x11 43 I think I need a 12inch wheel to because of the wheel is wider than the rim.
Here is a 325 vs 345 comparison. Had had any problems just a look preference.
Old 01-27-2020, 10:43 PM   #9
XXX ZL1
XXX ZL1's Avatar
Drives: 2023 ZL1 M6
I’m running 19x12 with a 325/30. Fits and looks great.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp, Jet
Hot Coated ARH 2 inch LT's, Stainless Works NPP, Too
High PSI Billet Valve Covers, Mighty Mouse Wild CC
Signature Forged 20x10.5/20x11.5, 295/30-315/30,
BMR springs, BMR Cradle lockout, AAD Billet
Control/Trailing arms
2023 Vivid Orange ZL1 M6 - sold
2019 Riverside Blue ZL1 A10 - sold
XXX ZL1 is offline   Reply With Quote
Old 01-28-2020, 10:14 AM   #10
TheElementalCashew
TheElementalCashew's Avatar
Drives: 2017 ZL1
Thanks.
I'm running 19x10 (+20) and 19x12 (+56) with PS4S (305) up front and R888Rs (325) in the back. No rubbing or other modifications required with my setup.
I know you said you don't want to do the R888Rs, but it sounds like you've got more power than me and the Toyos are the only ones that have done the job for me so far. Then again, if you are doing HPDEs maybe sticking with the PS4S would be better.
2017 Camaro ZL1, Nightfall Gray Metallic: M6, PDR, exposed CF, navigation, sunroof
Mods: Rotofab CAI, Tony Mamo TB, Kooks headers (green cats), 18% LPE lower pulley, E85/FlexFuel sensor. BC Forged RS41s (19x10, 19x12)/PS4S, R888R (305/325)
Dyno: E40: 661whp/703wtq, 93: 633whp/674wtq
TheElementalCashew is offline   Reply With Quote
