Old 01-28-2020, 06:43 AM   #29
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2019 GMC Sierra 1500 AT4
My 100% guess on this is something wrong with the transmission output speed sensor or its circuit (wiring, ECM input, etc.).
There is a speed sensor on the output shaft of the transmission (OSS). Likely Chevrolet compares the output shaft speed to the engine speed in a control module. Normally they should be locked at whatever gear ratio you are in, but if the clutch is slipping, there will be a mismatch in that comparison. That would trigger this error in normal situations (actual slipping clutch being normal). Could also be that that particular sensor is used an an input to the speedometer as well.
See here for sensor location. Looks like passenger side near the rear. Gonna be tricky to get to/see with the cross member in the way, though.
https://ls1tech.com/forums/manual-tr...onnectors.html
See here for replacement procedure:
http://juchems.com/ServiceManuals/vi...)%20Sensor.pdf
I didn't find the part number for it, but I didn't look very hard either. Maybe just a loose sensor or connection, though. Maybe I'm 100% wrong too.
edit: here's a case where it happened in an auto: https://www.camaro6.com/forums/showthread.php?t=511494
Summit White
6" Lift, 37x13.50R24's
geaux_tigerss is offline   Reply With Quote
Old 01-28-2020, 02:45 PM   #30
wintertopdown
Drives: 22 Convertible V8 LT1
I have the v6 matched with a tremac 3160. Any idea on the part #?
wintertopdown is offline   Reply With Quote
Old 01-29-2020, 07:16 AM   #31
wintertopdown
https://www.gmpartsgiant.com/parts/g...-19355499.html
Part Description SENSOR ASM,M/TRNS OUTPUT SPD
Old 01-30-2020, 03:34 AM   #32
NeilMc
Drives: Cadillac CTS-V
Hi Guys,
It's taken me a couple of days to get registered for the site, and it sounds like you've got to the point I was at a couple of days ago.
I work at a GM dealership in the United Kingdom. We have a Corvette Grand Sport with this exact issue. The GM technical team in Europe haven't responded to our request for assistance yet, but our diagnostics is telling us that it's most likely the manual transmission output speed sensor. It's common between all the Corvettes and Camaros with a manual transmission.
Our problem is that this car faults so irregularly, that even when we replace the sensor, it might take days or weeks until we know if it's fixed. We have one on order, but it would be nice if somebody else with the fault could also feed back if the issue is resolved after replacing this sensor.
NeilMc is offline   Reply With Quote
Old 01-30-2020, 11:31 AM   #33
wintertopdown
I ordered the part from gmpartsgiant and will provide updates upon replacement.
The car is about to hit 85,000 miles.
Old 02-05-2020, 09:00 PM   #34
wintertopdown
The part has not yet shipped. Meanwhile the compass of the car is all screwed up too.
Old 02-06-2020, 11:14 AM   #35
Jb54
Drives: 2019 Camaro SS M6
Hi. Your car, by chance doesn't have an aftermarket throttle controller on it does it? I had a similar problem. Reduced power(limp mode). Saying , there could be an unclipped harness plug down by your accelerator pedal, not registering correctly on your throttle control sensor. Or it could be a bad throttle control sensor. I removed the throttle controller completely. Reset the system and no more problems. I would look there and your connection on the throttle body for starters. Good luck.
Jb54 is offline   Reply With Quote
Old 02-11-2020, 01:11 PM   #36
wintertopdown
The part seems to be on back order and I have not had the opportunity to swap it out
Old 02-20-2020, 10:56 AM   #37
wintertopdown
I received the wrong party, perhaps it is for the v8 transmission
Old 02-20-2020, 11:01 AM   #38
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
this could be due to a bad ground, maybe burned wires?
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 02-20-2020, 11:45 AM   #39
wintertopdown
I was looking at the wrong area of the tremac 3060. Attached is a photo and as described by my local Chevrolet parts dealer, the output speed sensor (the unplugged wire) is next to the reverse sensor. I removed the bolt with an Allen key and pulled the sensor out slowly. I did hear an air seal release. Afterwards, I put the new one in and started the motor. No codes appeared.
Time for a test drive but first a much needed interior and exterior cleaning. 89102 miles on the odometer and I just replaced my second exhaust solenoid on bank 2 as well.
I will update soon
Old 02-20-2020, 06:50 PM   #40
wintertopdown
STILL RECEIVING THE SAME MESSAGE IN FIFTH AND SIX GEARS
Old 02-21-2020, 06:20 AM   #41
geaux_tigerss
I'd check the connection and the wiring all of the way back. Could also be ECM related (on the input where it receives the input). Some guys had a similar intermittent issue with flex fuel kits by not seating the pin in the ECM connector all of the way.
Summit White
Old 03-09-2020, 05:59 AM   #42
wintertopdown
Any other ideas, Besides loose wires?
