Old 03-11-2020, 09:12 AM   #1
Chomorro
Drives: 2010 Camaro SS
Traction control doesnt prevent fishtails?
This is my first v8 rwd car and it started raining here pretty hard. Took the 6 speed camaro SS at about 15mph in second and gave it just a tiny bit of gas to get on the freeway and the rear slid out like I was on ice (ca no ice).
I almost did a uturn on the freeway on ramp and I was able to save it. I'm just curious, if both rear wheels are spinning equally then traction control doesnt kick in?
Sent from my SM-N950U using Tapatalk
Chomorro is offline   Reply With Quote
Old 03-11-2020, 09:15 AM   #2
GAD
GAD's Avatar
Drives: Silver 2014 Camaro 2SS
How good are your tires? My tires are bad but it’s nothing for me to spin a donut in a parking lot with traction control on.
2014 Silver 2SS L99 with Roto-Fab CAI, Kooks LT Headers, Kooks Cat-less 3” exhaust, TS Stage 3.2 VVT CAM, Circle D 3200 Stall, E85 Kit, FIC 850cc injectors and Elite Engineering Catch Can. Dynoed at 478rwhp.
GAD is offline   Reply With Quote
Old 03-11-2020, 09:44 AM   #3
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
I thought this is where Stabili-Trak took over. Sort of senses vehicle yaw and applies the brakes to 'help' prevent more fishtail. But once momentum has started in that direction, it'll likely overpower the braking action of stabili-trak, the way I see it. Especially on a wet surface.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
Moto-Mojo is offline   Reply With Quote
Old 03-11-2020, 09:53 AM   #4
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Traction control should kick on but it still allows the tires to spin slightly and it takes a moment to kick in. Under a certain speed stability control won't activate. My advice, take in in a big parking lot when it is raining and turn everything off and learn your car and how to control it.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
Greenhornet2 is offline   Reply With Quote
Old 03-11-2020, 10:01 AM   #5
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Traction control doesn't care about hydroplaning, which sounds like is what happened to you.
Good tires are the best thing you can do for traction, being safe with the throttle is the next. The nannies can only do so much.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 03-11-2020, 10:11 AM   #6
Chomorro
My tires arent new but not completely bald either. There wasnt much visible rain on the ground at this point so I dont think it was hydro. I was also barely accelerating because it was raining.
I had a 450whp subaru before this. That AWD really makes a difference, never had to worry about this kind of thing lol.
Have to be very careful in the rain with this bad boy it seems.
Old 03-11-2020, 10:40 AM   #7
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
I have brand new tires on my car and at times when it’s wet out it wants to go sideways a little bit. Never had it happen at any higher speeds fortunately only at lower speeds speeding up.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 03-11-2020, 11:46 AM   #8
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
I can spin the tires in my car at will, wet or dry. But I find its stability is actually quite amazing. As long as I do not disable the nannies, she is well behaved in the wet, as long as I am. Also, tires make a huge difference in wet driving.
The only way my car fishtails in the rain is if I am giving it too much throttle for the conditions. Just saying. You may need to adjust your driving and get a little more conservative until you have more experience with this car.
InFiD3ViL is offline   Reply With Quote
Old 03-11-2020, 12:05 PM   #9
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
Traction control will let the car slip for a little bit before it catches depending on speed and throttle input.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 03-11-2020, 12:56 PM   #10
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
The only time I've had real issues similar to that was soon after I got my car. The reason for the issue was that the inside of the tire was worn to almost bald while the outside of the tire still looked good. The reason was that the previous owner had lowering springs on the car and had put the stock springs back on when he sold it to me. However, he hadn't aligned the car and so the inside of the tires wore out bad because the alignment was off the chart worn out. My guess as you somewhat indicated, is that the tires aren't new and potentially there's a worn side to them possibly from a bad alignment and you're going to have this issue until you buy some new tires.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 03-11-2020, 12:59 PM   #11
Vegas Bound
Drives: 2013 Sparkly Red One
If you still have the P Zeros, they suck on wet surfaces.
Vegas Bound is offline   Reply With Quote
Old 03-11-2020, 01:01 PM   #12
CamaroBarb
Drives: cheby Camaro
Mine will do circles in the wet and nothing happens to stop it.
CamaroBarb is offline   Reply With Quote
Old 03-11-2020, 01:09 PM   #13
Chomorro
With traction control on right?
Old 03-11-2020, 01:13 PM   #14
MarkNJ
MarkNJ's Avatar
Drives: 2015 2SS Commemorative Edition
You drive yours in the rain!?
MarkNJ is offline   Reply With Quote
