01-25-2018, 08:23 PM | #1 |
Drives: 17 SS a8 Join Date: Feb 2010
bolt size to plug oil drainback from factory seperator
there is a metal pipe leaving the oil separator behind the water pump. it leads down to the oil pan. i would like to remove it and plug the hole. it looks like a bolt would do it if i knew what to order. does anyone know the specs on that bolt or have a clean way to plug that hole? i could take it somewhere and have it welded shut i suppose.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
04-18-2021, 06:59 AM | #2 |
Madman
Drives: 2018 2SS Optioned 6spd Summit White Join Date: Aug 2020
did you ever plug it? what was the size?
04-18-2021, 12:23 PM | #3 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
Out of curiosity. Why?
